• 05.02.2023, 13:01
Aquacomputer parts with EK(soon Aquacomputer) pumps and fans Lian Li - Aquasuite
Friday, November 11th 2022, 11:20pm
Planning to use Leakshield and Flow Next form Aquacomputer with EK pumps and Lian li fans.
Would love to quit iCue and start using Aquacomputer software to control everything.
  1. What cables, hubs I need?
  2. What connections I need to what hardware?
  3. Is Leakshield working with Dual pump(will use Mo-ra3 with dual pump on it)?
    Found below on FAQ pdf of leakshield
    "Does LEAKSHIELD work if I connect two pumps in series? This depends on the set speed and the generated pressure of the pumps. Again, 470 mbar is the maximum total pressure. If the pumps in total exceed the pressure at the set speed, LEAKSHIELD can only be used as a leakage monitor. Protection against leakage of the coolant is no longer provided in this case."
