• 05.02.2023, 11:33
lawshadow
RTX 4080 or RTX 4090 water blocks which RTX 4000 to get?
Friday, November 18th 2022, 12:30am
Hi all,
So i know Aquacomputer is working on a waterblock for the RTX 4090 TUF and STRIX.
I am contemplating which card to get either a RTX 4080 or RTX 4090 or even a RX7900XTX.
Most important question is the Aquacomputer waterblock for the RTX 4090 TUF and STRIX also compatible with the RTX 4080 TUF and STRIX since they have a similar PCB correct?
Am i forced to get either a TUF or STRIX are there plans to have waterblocks for different brands of RTX 4080/4090?
If i am down to only TUF or STRIX i need to know before i make a possible purchase and not get hugely dissapointed with a wrong purchase ie waterblock DOES NOT fit!
Thanks in advance
