• 26.04.2024, 06:42
Kryos Vario pressure test - air leak from adjustment screws
Freitag, 6. Januar 2023, 04:41
Hi all. I thought I'd post here before contacting support in case it's a non-issue.
I ran a pressure test on my loop prior to filling and noted air leaking at a fairly high rate from the newly installed Kryos block (fresh out of packaging). I took it out and after further testing have determined that air is leaking from the adjustment screws, and that tightening them as far as possible lessens (but does not eliminate) the air leak.
I realise that given the nature of the screws that it is possible that it isn't airtight but is watertight, but I didn't want to risk commissioning it without being sure. Is this a known / expected behaviour or should I contact Support about an RMA?
Thanks.
