• 26.04.2024, 15:05
Pressure Sensor + LEAKShield
Dienstag, 21. Februar 2023, 03:47
Hi, I am planning a new loop right now and will be re-using my Aquaero 6.
In the new loop, I'd like to add a Leakshield to the mix. I am also interested in monitoring pressure across the pump as well (no real good reason for this, just a want). However I wasn't sure if it is safe to use the Delta 1000 in the same loop that the LEAKshield is in where vacuum pressures will be pulled.
Is it OK to have a LEAKshield on my reservoir with a Delta 1000 across the pump inlet/outlet?
