• 27.04.2024, 21:22
hugemon
Minor problem with RGBpx with multi display system.
Sonntag, 5. März 2023, 16:31
I use RGBpx + Aquasuite to control my bias lighting behind my monitor. (Only one monitor has the lighting.)
The problem is that when ever system boots or monitor wakes up from sleep Aquasuite sometimes forgets which monitor should control the lighting.
I think the problem is with Aquasuite detecting both monitors in different order whenever it detects them.
I think Display selection from AMBIENTpx setup dialog should have an option to remember what resolution monitor it was set as not monitor order (as it can change after reboot or monitor wake up.)
At least it would help me because my monitors have different resolutions. (Well too bad for folks with multiple identical monitors.)
