Sie sind nicht angemeldet.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Speedy-VI« (31. März 2023, 04:48)
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Methodical« (31. März 2023, 08:27)
Thanks. So, they don't list the information for this product. I guess they consider it proprietary or something. Just an FYI. They do provide the various mixture ratio (10%-60%) for the concentrate on their website and in their manual. You can make it as strong or weak as needed.they don't list all those physical characteristics, only the constituents.
Here it's <90% ethylene glycol and <8% DI water. the missing % is their secret sauce so there's no saying what it does to conductivity already.
Oddly enough they sell that one as a concentrate but the end product is a glycol mixture like the DP ultra. And as for the conductivity, it will be highly variable because it will mostly depend on the quality of the water you will dilute it into, how much water you use (yes, they don't specify any water/ concentrate ratio), and those mysterious additives they do not list in the MSDS.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Methodical« (1. April 2023, 03:50)
Coolants that use the "additive" style EK does (you often can purchase them as concentrates) will read too high.
Coolants based on glycol like DP ultra (that you usually can't find as concentrates) will read low and may work with the High flow next basically.
To know which is which, you'll have to look at the MSDS of the coolant you want to use. it may give you a clue as to what you can expect. DP ultra from the datasheet is 20-35% ethylene glycol and less than 1% of anticorrosion additive.
Cryofuel uses another anticorrosive that renders the water more conductive, plus a biocide, but it's less viscous than a glycol mixture (all things relative.. it's not honey thick :p the tiny correction factor on the HFN shows how small the difference is) and glycol lowers the heat capacity of the coolant somewhat (but it doesn't matter one bit for PC watercooling either. It's only useful to know when calculating the dissipated power, for watercooling nerds).
Both options are perfectly fine. the EK approach is closer to the old DIY coolant where people use DI water and add a few drops of biocide and anticorrosive. AC looks closer to the AIO approach of using a glycol mix.
Soooo yep. if you care about the conductivity sensor, by all means go DP ultra. Using any other coolant, you won't be able to tell when it needs to be changed, since... there's no saying what acceptable values are.
... and on a personal note.. those additives used in cryofuel and other similar coolants are pretty nasty. I still use Cryofuel personally, but i have had some pretty severe skin rashes when accidentally exposed to it. These definitely require gloves when doing a coolant change. Glycol based coolant are a lot safer to be honest.
See? you ask a simple question and we go above and beyond to complicate the answers lol
Thanks for the detailed answer ,I contacted ek and asked for the conductivity of the mystic fog and was told conductivity of coolants is not available to the public!!
I could not find a post from Remayz where he said that he contacted EK and was told the conductivity of their coolants is not available to the public. Either the quote is messed up, the post was deleted or altered, the forum search functions have issues, or I am blind.Thanks for the detailed answer ,I contacted ek and asked for the conductivity of the mystic fog and was told the conductivity of coolants is not available to the public!!
is it true i need to use only dp ultra with the next high flow next ?
or is it ok to use with other coolants out there?
I suspect that like most if not all of Corsair's cooling loop products, they are just rebranding coolant made by another company. A quick Google search for an MSDS sheet returned the attached. The MSDS sheet says their coolant is ultra-pure water with <20% 1,2-Propanediol which is Propylene Glycol. It also contains <1% of an unspecified Germicide Since it is Glycol based, it is not surprising that it has a conductivity similar to DP Ultra which uses Ethylene Glycol. Propylene Glycol is less toxic, but it also has a higher viscosity which lowers heat transfer efficiency. Since the conductivity of XL8 is within the range of the conductivity sensor in the High Flow Next, the conductivity sensor should work OK. Since PG has a higher viscosity, the flow rate accuracy may be affected. Your pump will also have to work a little harder to push the fluid through the loop.Not sure if it's any help, but I'm using Corsair XL8 (Clear) in my loop. Had it running for the last 6 months or so, and the High Flow Next reads the Conductivity currently as 32.9 uS/cm.
