• 07.05.2024, 23:38
Questions on Ultitube 150 Pro D5 Next
Sonntag, 13. August 2023, 16:31
I'm planning on using the 120mm fan mount to attach my Ultitube D5 150 Pro with the D5 Next pump to a Airplex Radical 2 /360 in a vertical mode. It shows in the pics using the X plate and the L bracket. Which one is the best to use under what circumstances?
Am I assuming correctly that the Ultitube is designed so that if you need a smaller or larger reservoir that you just buy the appropriate glass tube and switch them out?
See the link about the pics:
https://shop.aquacomputer.de/product_inf…roducts_id=3855
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Top_Nurse« (14. August 2023, 09:25)
