• 03.04.2026, 09:47
sobtybor6bif
Externe Sensoren
Samstag, 22. April 2023, 17:27
ich würde gerne ein paar externe Sensoren (z.B. von HomeAssistant) in die Aquasuite bekommen.
z.B. die Raumtemperatur als Ausgangslage für die Wassertemperatur/Lüfterkurve.
Gibt's da komfortable Möglichkeiten oder APIs, das zu tun?
Samstag, 22. April 2023, 19:18
I have seen this question be asked before and the answer is always NO. Aquasuite can import sensor data from HWINFO and AIDA. I think that is it. For ambient room temperature you can install a temp sensor located outside of the computer case. Plug the temp sensor into an Aquacomputer device that has temp sensor inputs (Octo, Quadro, High Flow Next, Farbwerk360. etc.).
sobtybor6bif
Samstag, 22. April 2023, 21:10
Fair enough. Thanks
