• 03.04.2026, 04:58
Cora-Partido
Durchflußsensor für Aquaero
Dienstag, 10. August 2004, 19:47
Sorry for writing in English but I don't know German.
I've bought in my country (Portugal) one flow sensor for aquaero but I didn't bought yet the cable that connects the sensor to the aquaero. It seems my shop doesn't have this cable and I need to wait some weeks till they having it.
So can someone please help me in the pinout of the sensor, until the correct cable arrives.
Many thanks
Best Regards
lucky777
Re: Durchflußsensor für Aquaero
Dienstag, 10. August 2004, 21:04
If you loock very carefully  ;) onto the flow-sensor you'll find the meaning of the pins ;)
But anyway, the middle pin is the signal pin, and if you hold the sensor, the cooling in/output point's at you, the left one ist the power (+4,5V to +24 V) and the right one ist the GND (-).
Hopefully this is what you wanted to know. ;D
If you'll use a different kind of flow-sensor which AC recommend ( see at onlineshop ) then I have no idea how the pins are set. But you can measure this out via the resistance of the pins !! 8)
LianLi PC V2000 ASUS A8V Deluxe AMD Athlon 64 3800+ ( 25°C - 42,3°C full load ) Gigabyte GVR80 X800PRO 480 GB HDD SAMSUNG Spinpoint's 2 GB CORSAIR PC3200 XL PRO YESICO 420 W Netzteil ...and a lot of AC-stuff
Cora-Partido
Dienstag, 10. August 2004, 21:30
Many Thanks!!!!
Fragom
Mittwoch, 11. August 2004, 18:53
This handle is correct?
Thanks
Site: FaceNaWeb [img]http://seti.familie-friedrich.de/userstats.php?l=6&id=884[/img]
lucky777
Mittwoch, 11. August 2004, 19:03
I'll check it ...... work in progress ;)
Hi-Ho ! It seems that AC has already crossed the output in the Aquaero. Very smart :o
The correct wiring is: Let the MOLEX-Plug at the AE as it is and switch the BLACK wire with the YELLOW one at the flow-sensor :-[
This is the reason why the flow sensor won't work at one of the "normal" fan connectors, anyway just switch the to wires then it's ok.
Yours
Dragonclaw
Mittwoch, 11. August 2004, 19:09
i think theres a problem...but i did not find it yet ::)
checking too ;)
update:
lucky777 is right ;)
black and yellow have to be changed
Fragom
Mittwoch, 11. August 2004, 19:24
They pardon but I do not understand.  But I intend that correct of this handle says which to me the linking:  Pin 1, 2 and 3 of the Aquaero goes to bind to the Pin # | + of the Flow Sensor.  Which the correct position.  Thanks.
Dragonclaw
Mittwoch, 11. August 2004, 19:46
conector "Flow"
Pin 1 (right): signal (on the sensorpicture above: #, right)
Pin 2 (middle): +5V (sensor: +, left)
Pin 3 (left): ground (sensor -, middle)
Fragom
Mittwoch, 11. August 2004, 20:21
Zitat von »Dragonclaw«
conector "Flow"
Pin 1 (right): signal (on the sensorpictur above: #, right)
Many Thanks.
Dragonclaw
Mittwoch, 11. August 2004, 20:34
no problem, but wait with saying thank you until it works ;)
Fragom
Donnerstag, 19. August 2004, 02:40
Sorry, but I have a problem. When installing the Flow Sensor in accordance with the project above, this does not function.
After seeing in detail the project, I think that:
Pin 1 (GND) Aquaero binds Pin T (half) Flow
Pin 2 (5V) Aquaero binds the Pin + (left) Flow
Pin 3 (rpm) Aquaero binds to the Pin # (right) Flow
Will be that thus he is correct the linking?
Donnerstag, 19. August 2004, 03:37
That's the wiring on my system and it works :)
Fragom
Donnerstag, 19. August 2004, 18:43
Ok, that connection is agreement with what above said but the Pin1 of the Aquaero is in right interest: the sequency is 3 - 2 - 1, ok?
Donnerstag, 19. August 2004, 19:03
No idea if it is numbered from left to right or the other way ;) Just look at the wiring and try this; it should work.
Dragonclaw
Donnerstag, 19. August 2004, 19:35
well, in the manual it's nubered from right to left... ::)
but soon we'll have all possible combinations tested :D
Fragom
Freitag, 20. August 2004, 03:07
ok, now already functions with this configuration! Finally!!!
jcab
Dienstag, 24. August 2004, 02:32
Olá Face ;D
