• 13.02.2026, 16:33
Guffen
How can i feed jaLCD with aquaero info?
Sonntag, 10. Oktober 2004, 02:38
How can i feed the jalcd with informasjon from the aquaero?
I like to build my layout on the aquaero display.
Please don't replay i german, i don't speak it. :-X Thank you
Re: How can i feed jaLCD with aquaero info?
Sonntag, 10. Oktober 2004, 03:18
Currently it's not possible to import data directly from the aquaero to jalcd.
If you have some programming knowledge you should be able to create a small tool which writes the data to a text file. This text file could be used with jalcd.
