• 14.04.2026, 20:55
friku
Aquaero incorrect file flashing :(
Freitag, 13. Mai 2005, 16:30
Hi everyone:
I´ve made a big mistake in flashing. I´ve a lcd version of the aquaero controller, and have flashed the vfd version.
Now windows doesn´t recognise me any aquaero conected to usb headers, and nothing is displayed on the aquaero. Fans are on 100% of power every time...
How can I solve this problem? How can I reflash the aquaero?
Thanks.
Cheers,
friku.
x-stars
Re: Aquaero incorrect file flashing :(
Freitag, 13. Mai 2005, 16:47
??? - if you have flashed the new Version (4.xx) you aren't able to make a mistake because there is juast one version (the AE recognize the right display automaticially) ;).
friku
Freitag, 13. Mai 2005, 16:48
Resolved:
Completely shutdown of computer. Disconected power from PSU. Restart. Reflash with LCD version file. All fine.
Sorry for the shocked question. But was afraid that I couldn´t solve the problem.
Thanks anyways for reading.
Cheers,
friku.
friku
Freitag, 13. Mai 2005, 16:49
Thanks for your answer X-stars.
Haven´t seen the 4.xx version. Should look better?
Thanks,
friku.
x-stars
Freitag, 13. Mai 2005, 16:53
It's a whole new development (new firmware AND new software, the software is much better than the old one). You can get the files in the download-area of aqua-computer, in the english forum you'll find a topic where is a link inside with an translation of the "How to flash"-paper :).
friku
Samstag, 14. Mai 2005, 20:47
Many thanks X-Stars for your advices...
Have installed the 4.xx version correctly, al works fine...
The fans don´t go up at 100% so often as before. This firmware version works a lot better I think.
For me reading the install manual in German isn´t a problem, but writing in German is a little bit more difficult... ;)
Thanks again,
friku.
