• 15.04.2026, 16:26
lord_fritte
Linux: aeinfo lässt sich nicht installieren
Samstag, 11. November 2006, 15:36
Hallo ich habe Kanotix 32-Bit mit einem 2.6.18 kernel wenn ich versuche aeinfo 2.2 zu installiere mkommt dies:
Quellcode
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
tobias@tobias-kanotix32:~$ cd aeinfo-2.2-src
tobias@tobias-kanotix32:~/aeinfo-2.2-src$ make
cat htdocs/fan.1.htm | sed -e "s/FAN 1/FAN 2/" -e "s/fan.1/fan.2/g" > htdocs/fan.2.htm
cat htdocs/fan.1.htm | sed -e "s/FAN 1/FAN 3/" -e "s/fan.1/fan.3/g" > htdocs/fan.3.htm
cat htdocs/fan.1.htm | sed -e "s/FAN 1/FAN 4/" -e "s/fan.1/fan.4/g" > htdocs/fan.4.htm
cat htdocs/sensor.1.htm | sed -e "s/SENSOR 1/SENSOR 2/" -e "s/sensor.1/sensor.2/g" > htdocs/sensor.2.htm
cat htdocs/sensor.1.htm | sed -e "s/SENSOR 1/SENSOR 3/" -e "s/sensor.1/sensor.3/g" > htdocs/sensor.3.htm
cat htdocs/sensor.1.htm | sed -e "s/SENSOR 1/SENSOR 4/" -e "s/sensor.1/sensor.4/g" > htdocs/sensor.4.htm
cat htdocs/sensor.1.htm | sed -e "s/SENSOR 1/SENSOR 5/" -e "s/sensor.1/sensor.5/g" > htdocs/sensor.5.htm
cat htdocs/sensor.1.htm | sed -e "s/SENSOR 1/SENSOR 6/" -e "s/sensor.1/sensor.6/g" > htdocs/sensor.6.htm
g++ -Wno-deprecated -DUSE_COLORS -Wall -lusb global.cpp -o aeinfo
In file included from comm.h:24,
                 from global.cpp:60:
usbio.h:33:18: error: usb.h: Datei oder Verzeichnis nicht gefunden
definePropMap.h: In function ‘void definePropertyMap(AquaeroData_rev4&)’:
definePropMap.h:165: warning: large integer implicitly truncated to unsigned type
definePropMap.h:166: warning: large integer implicitly truncated to unsigned type
definePropMap.h:167: warning: large integer implicitly truncated to unsigned type
definePropMap.h:168: warning: large integer implicitly truncated to unsigned type
definePropMap.h:169: warning: large integer implicitly truncated to unsigned type
definePropMap.h:170: warning: large integer implicitly truncated to unsigned type
comm.h: At global scope:
comm.h:14: warning: ‘class AquaeroCommunication’ has virtual functions but non-virtual destructor
usbio.h:128: error: ISO C++ forbids declaration of ‘usb_dev_handle’ with no type
usbio.h:128: error: expected ‘;’ before ‘*’ token
usbio.h:249: error: ‘usb_dev_handle’ has not been declared
usbio.h:433: error: ISO C++ forbids declaration of ‘usb_dev_handle’ with no type
usbio.h:433: error: expected ‘;’ before ‘*’ token
usbio.h:549: error: expected `;' before ‘string’
usbio.h: In member function ‘void USBCommunication::close_device()’:
usbio.h:181: error: ‘open_handle’ was not declared in this scope
usbio.h:181: error: ‘usb_close’ was not declared in this scope
usbio.h: In member function ‘usb_device* USBCommunication::init_device()’:
usbio.h:272: error: ‘usb_init’ was not declared in this scope
usbio.h:273: error: ‘usb_find_busses’ was not declared in this scope
usbio.h:274: error: ‘usb_find_devices’ was not declared in this scope
usbio.h:276: error: ‘usb_get_busses’ was not declared in this scope
usbio.h:276: error: invalid use of undefined type ‘struct usb_bus’
usbio.h:269: error: forward declaration of ‘struct usb_bus’
usbio.h:278: error: invalid use of undefined type ‘struct usb_bus’
usbio.h:278: error: invalid use of undefined type ‘struct usb_device’
usbio.h:266: error: forward declaration of ‘struct usb_device’
usbio.h:280: error: invalid use of undefined type ‘struct usb_device’
usbio.h:281: error: invalid use of undefined type ‘struct usb_device’
usbio.h: In member function ‘std::string USBCommunication::readAEString()’:
usbio.h:551: error: ‘usb_dev_handle’ was not declared in this scope
usbio.h:551: error: ‘aq’ was not declared in this scope
usbio.h:551: error: ‘get_aquaero_handle’ was not declared in this scope
usbio.h:562: error: ‘usb_interrupt_read’ was not declared in this scope
usbio.h:598: error: ‘usb_close’ was not declared in this scope
usbio.h: In member function ‘void USBCommunication::writeAEString(std::string)’:
usbio.h:621: error: ‘usb_dev_handle’ was not declared in this scope
usbio.h:621: error: ‘aq’ was not declared in this scope
usbio.h:621: error: ‘get_aquaero_handle’ was not declared in this scope
usbio.h:640: error: ‘usb_control_msg’ was not declared in this scope
usbio.h:696: error: ‘usb_close’ was not declared in this scope
ipc.h: At global scope:
ipc.h:1080: warning: ‘class AquaeroDaemonService’ has virtual functions but non-virtual destructor
global.cpp: In function ‘int main(int, char**)’:
global.cpp:380: warning: unused variable ‘ret’
make: *** [all] Fehler 1
hurra
Re: Linux: aeinfo lässt sich nicht installieren
Samstag, 11. November 2006, 19:25
Du brauchst wohl installierte Kernelquellen. Eventuell tuts auch mit linux-headers.
composer
Sonntag, 12. November 2006, 15:45
Quellcode
1
Auf Deinem System ist die libusb nicht installiert. Für die Kompilierung wird unter Umständen auch ein libusb-devel-Paket benötigt...
Wenn ich irgendwann mal etwas mehr Zeit habe werd ich das Paket auf autoconf/automake umstellen ;-)
Ach ja - und vermutlich wird es kommende Woche aeinfo-2.3 mit kleinen Fixes geben (vor allem wird ein Webserver-Problem mit Linux-2.6 behoben)
lord_fritte
Donnerstag, 16. November 2006, 23:50
was ich toll fände, ist eine kleine Deutsche Anleitung ^^ xD
composer
Samstag, 18. November 2006, 13:15
Ist doch dabei ;-) siehe README
lord_fritte
Samstag, 18. November 2006, 20:02
Ich hab libusb-dev jetzt installiert, es lässt sich aber trozdem nicht installieren:
Quellcode
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
root@tobias-kanotix-vmware:/home/tobias/Desktop/aeinfo-2.2-src# make
g++ -Wno-deprecated -Wall -lusb -lpthread aquaerod.cpp -o aquaerod
aehttpd.cpp: In member function ‘std::string ScriptParser::executeScript(std::string, std::string)’:
aehttpd.cpp:713: warning: comparison between signed and unsigned integer expressions
aehttpd.cpp:747: warning: comparison between signed and unsigned integer expressions
aehttpd.cpp:813: warning: comparison between signed and unsigned integer expressions
aehttpd.cpp: In member function ‘bool HttpResponse::checkURI(std::string)’:
aehttpd.cpp:1248: warning: comparison between signed and unsigned integer expressions
lex.yy.c: At global scope:
lex.yy.c:1008: warning: ‘void yyunput(int, char*)’ defined but not used
Ich glaube ich warte einfach auf eine spätere Version
hurra
Samstag, 18. November 2006, 21:19
Das sind doch jetzt nur warnings, sollte also schon geklappt haben.
lord_fritte
Sonntag, 19. November 2006, 20:23
und wie kann ich das testen? muss nun im Ordner ein *.deb packet vorliegen?
hurra
Sonntag, 19. November 2006, 22:14
Nein.
Normalerweise liegt eine executable vor.
Mit `make install` als root kannst du das Programm systemweit installieren.
composer
Dienstag, 21. November 2006, 12:19
Ja das sind wohl nur Warnings (vielleicht sollte ich mal den -Wall-Schalter entfernen)...
Wenn Du bereits "make install" eingegeben hast, kannst Du es durch die Eingabe von aeinfo ausprobieren.. Sehr ans Herz lege ich Dir auch das README ;-)
