• 20.03.2026, 21:55
Antagonist
Microsoft .NET framework
Sunday, July 17th 2005, 3:34am
Hallöchen zusammen
habe ein kleines Problem mit der Software. Ween ich Aquasuite starte kommt folgende Fehlermeldung:
klick
Was mag es sein? Habe NET schon mal komplett neu installiert aber es bringt nix....
MfG Mark
pharao
Re: Microsoft .NET framework
Sunday, July 17th 2005, 11:41am
was steht denn da, wen man auf "Details" klickt?
Antagonist
Sunday, July 17th 2005, 12:55pm
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Data.OleDb.OleDbException: Fehlt
at System.Data.OleDb.OleDbCommand.ExecuteCommandTextErrorHandling(Int32 hr)
at System.Data.OleDb.OleDbCommand.ExecuteCommandTextForSingleResult(tagDBPARAMS dbParams, Object& executeResult)
at System.Data.OleDb.OleDbCommand.ExecuteCommandText(Object& executeResult)
at System.Data.OleDb.OleDbCommand.ExecuteCommand(CommandBehavior behavior, Object& executeResult)
at System.Data.OleDb.OleDbCommand.ExecuteReaderInternal(CommandBehavior behavior, String method)
at System.Data.OleDb.OleDbCommand.ExecuteReader(CommandBehavior behavior)
at System.Data.OleDb.OleDbCommand.System.Data.IDbCommand.ExecuteReader(CommandBehavior behavior)
at System.Data.Common.DbDataAdapter.FillFromCommand(Object data, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior)
at System.Data.Common.DbDataAdapter.Fill(DataTable dataTable, IDbCommand command, CommandBehavior behavior)
at System.Data.Common.DbDataAdapter.Fill(DataTable dataTable)
at aquasuite.DatabaseAccess.GetWindowParamter(Int32 DeviceID, myWindowParameterStruct& WindowParameter)
at aquasuite.DatabaseAccess.LoadWindowParameter(myWindowParameterStruct& WindowParameter, Form& Form)
at aquasuite.frm_Main.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Antagonist
Sunday, July 17th 2005, 12:56pm
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
aquasuite
Assembly Version: 1.0.2008.12546
Win32 Version: 1.0.2008.12546
CodeBase: file:///C:/Programme/Aqua%20Computer/aquasuite/aquasuite.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
MyUSB
Assembly Version: 1.0.2008.12545
Win32 Version: 1.0.2008.12545
CodeBase: file:///C:/Programme/Aqua%20Computer/aquasuite/MyUSB.DLL
Microsoft.VisualBasic
Assembly Version: 7.0.5000.0
Win32 Version: 7.10.6001.4
CodeBase: file:///c:/windows/assembly/gac/microsoft.visualbasic/7.0.5000.0__b03f5f7f11d50a3a/microsoft.visualbasic.dll
SandBar
Assembly Version: 1.1.0.2
Win32 Version: 1.1.0.2
CodeBase: file:///C:/Programme/Aqua%20Computer/aquasuite/SandBar.DLL
System.Data
CodeBase: file:///c:/windows/assembly/gac/system.data/1.0.5000.0__b77a5c561934e089/system.data.dll
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
Sunday, July 17th 2005, 1:44pm
lade Dir bei Microsoft bitte einmal einen aktuellen OLEDB-Datenbank-Treiber herunter und installiere diesen. Anscheinend ist dieser bei Deinem Windows nicht installiert.
Antagonist
Sunday, July 17th 2005, 1:49pm
hmmm jo danke für die schnelle Antwort. Aber ich finden den glaube ich nicht?!
Ist es dieser hier?
http://www.microsoft.com/downloads/detai…&displaylang=de
oder dieses?
http://www.zdnet.de/downloads/prg/2/9/en10067329-wc.html
Wobei  bei der installation der oberen Software der Fehler kommt das es mit meinem Betriebssystem nicht kompatibel ist?!?! Und wenn ich die untere Software installiere kommt der selbe Fehler..... wie vorher auch :-[
MfG Mark
Antagonist
Wednesday, July 20th 2005, 1:57am
Hmm keine Antwort mehr??? Kann doch nicht sein das ich C:/ formatieren muss nur weil keiner mehr Rat weiß?! :-[
Wednesday, July 20th 2005, 2:39pm
Beide nicht.
Biite tippe einmal in Google OLEDB-Treiber ein. Dann sollten genug Treffer kommen.
Alternativ kannst Du (falls vorhanden) z.B. MS Access installieren.
Antagonist
Thursday, July 21st 2005, 3:06am
Hallo Stephan
habe Access installiert. Es Kommt immer noch der selbe Fehler  :-[ ... KAnnst du mir nich mal ein DL Link posten für einen OLEDB -Treiber? Ich glaube ich bin zu dumm einen zu finden. Komme immer auf diese Page:
http://www.microsoft.com/downloads/detai…de&Hash=CBJSRN7
wegen dem Treiber. Wenn ich das Installieren möchte, bekomme ich folgende Meldung:
MDAC 2.8 RTM ist mit dieser Version von Windows nicht kompatibel. Alle Funktionen sind zurzeit Teil von Windows.
Habe übrigens Window XP Home Edition auf dem aktuellsten Stand, wenn dir das weiterhilft. Fände ich super wenn du das machen könntest...
Danke im vorraus
MfG Mark
Antagonist
Monday, July 25th 2005, 9:42pm
Hmmm schade noch immer keine Antwort.... Ich habe noch mal alles versucht. Aber leider bringt alles nix.......
Muss wohl formatieren. Beim runterfahren kommt auch immer der fehler das der ...... NET Broadcast (oder so) nicht richtig beenden kann... alles sehr komisch
Monday, July 25th 2005, 9:43pm
Du kannst es ja erstmal mit einer sogenannten Rettungsinstallation versuchen.
Antagonist
Monday, July 25th 2005, 9:48pm
Rettungsinstallation??? Was meinst du? mit einer Diskette?? Oder mit der XP CD???
Oder wie?
Monday, July 25th 2005, 10:11pm
Mit der XP CD. Du drückst dich ganz normal zur Installation vor und dort wird dir dann die Rettungsinstallation angeboten. Das ist quasi eine normale Installation wobei hier alle Einstellungen usw. erhalten bleiben; es wird quasi nur das eigentliche Windows neu installiert.
Und ich meine nicht die Sache mit dem Reparieren, wo man dann die Disketten braucht etc.
Antagonist
Monday, July 25th 2005, 10:26pm
Jo besten dank werde es Gleich mal testen und mal sehen was passiert.....
MfG Mark
Antagonist
Tuesday, July 26th 2005, 12:01am
Habe es getestet........ aber wenn ich auf installieren klicke, kommt:
Installation kann nicht fortgesetzt werden, da die installierte Version aktueller ist :-[
Tuesday, July 26th 2005, 4:07am
Das kann durchaus sein, dass sich z.B. eine "nackte" XP Setup CD nicht mit dem installierten Windows samt Service Pack verträgt.
Ist aber auch kein Problem: Service Pack 2 in Windows-XP-CD integrieren
Antagonist
Saturday, July 30th 2005, 3:18am
Servus @ all hallöchen Shoggy
es funzt wieder alles.... leider aber erst nach einem Format C:
Trotzdem Danke für die Hilfe.
MfG Mark
