• 24.03.2026, 03:47
DooMMasteR
Installer Crashed mit Exception.
mercredi 18 mai 2022, 19:54
Ich kann die AquaSuite auf meinem Windows 11 aktuell nicht installieren, .NET 4.6.1 ist natürlich installiert.
Code source
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
Application: aquasuite_setup.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.Runtime.InteropServices.COMException
   at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32, IntPtr)
   at System.Management.ManagementScope.InitializeGuts(System.Object)
   at System.Management.ManagementScope.Initialize()
   at System.Management.ManagementEventWatcher.Initialize()
   at System.Management.ManagementEventWatcher.Start()
   at AquaComputer.UsbHid.UsbHid.uctnkJUlIoTkvki76Fc(System.Object)
   at AquaComputer.UsbHid.UsbHid.wuEh8XVdMm()
   at AquaComputer.UsbHid.UsbHid..ctor()
   at AquaComputer.Downloader.Views.DevicePage.sT8VkQklx3()
   at AquaComputer.Downloader.Views.DevicePage+NlRK8fDRrK0yXIUFNOJ.GuKby7SVTat()
   at System.Threading.Tasks.Task.Execute()
   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
   at AquaComputer.Downloader.Views.DevicePage+<myPage_Loaded>d__39.MoveNext()
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate, System.Object, Int32)
   at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate)
   at System.Windows.Threading.DispatcherOperation.InvokeImpl()
   at MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(System.Object)
   at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
   at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
   at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
   at MS.Internal.CulturePreservingExecutionContext.Run(MS.Internal.CulturePreservingExecutionContext, System.Threading.ContextCallback, System.Object)
   at System.Windows.Threading.DispatcherOperation.Invoke()
   at System.Windows.Threading.Dispatcher.ProcessQueue()
   at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
   at MS.Win32.HwndWrapper.WndProc(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(System.Object)
   at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32)
   at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr)
   at MS.Win32.UnsafeNativeMethods.DispatchMessage(System.Windows.Interop.MSG ByRef)
   at System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame)
   at System.Windows.Application.RunDispatcher(System.Object)
   at System.Windows.Application.RunInternal(System.Windows.Window)
   at AquaComputer.Downloader.App.Main()
Code source
1
2
3
4
5
6
7
8
9
10
11
Faulting application name: aquasuite_setup.exe, version: 2.6.0.0, time stamp: 0x60951422
Faulting module name: KERNELBASE.dll, version: 10.0.22000.652, time stamp: 0xd680f8f6
Exception code: 0xe0434352
Fault offset: 0x000000000004474c
Faulting process id: 0x386c
Faulting application start time: 0x01d86ae27783bfa6
Faulting application path: C:\Users\DooMMasteR\Downloads\aquasuite_setup.exe
Faulting module path: C:\Windows\System32\KERNELBASE.dll
Report Id: c4116cce-6ff0-424a-b1f3-317fa09087e5
Faulting package full name:
Faulting package-relative application ID:
Ce message a été modifié 1 fois. Dernière modification effectuée par "DooMMasteR" (18 mai 2022, 20:11)
DooMMasteR
vendredi 1 juillet 2022, 21:36
Ping, das Problem besteht noch immer.
samedi 2 juillet 2022, 06:24
Entweder ein Rechte Problem oder an deinem Windows ist etwas kaputt.
