• 05.03.2026, 14:21
Okipa
Aqua Drive Help...:)
Mittwoch, 2. Oktober 2002, 16:44
Hello,
I am french and i want to know how you can fix the aqua drive in the case...
i use the silent block with the aqua-drive but the drive doesn't go in the 5 1/4 bay...:(
Why i can do ?
THx...
WaterCooling is Good For Your Processor Health :D Just Noky It !!! :D
Motzky
Re: Aqua Drive Help...:)
Mittwoch, 2. Oktober 2002, 16:49
The AquaDrive is designed to fit in the 5 1/4" bay alone. Just screw the Harddisk into the Drive and then the Drive into the case.
XP1800+ @Cuplex, Gigabyte GA-7VTXH, 512mb PC266 CL2 Infineon, PixelView GF4 Ti4200@4600&Twinplex, IBM DeskStar 120GXP 60GB
Okipa
Mittwoch, 2. Oktober 2002, 16:52
Yes, but it does not return...
Okipa
Mittwoch, 2. Oktober 2002, 17:01
look on the foto...
slame
Mittwoch, 2. Oktober 2002, 17:12
push it deep inside man ;D
slame
Okipa
Mittwoch, 2. Oktober 2002, 17:13
Ok, it work, but i think this fixation wasn't good...:(
they may found an other..
