• 03.11.2026, 13:33
Hopsing
Re: DVD Brenner
vendredi 2 mai 2003, 11:31
also gut ich glaube ich werde den Pioneer nehmen, da er in vielen test als testsieger abgeschnitten hat und als ein sehr guter, stabiler und empfehlens werter brenner gilt.
danke für eure hilfe.
MFG
noid
Re: DVD Brenner
vendredi 2 mai 2003, 11:43
[tt]"What is the difference between DVD-R/RW and DVD+R/RW?
The truth is that the two competing technologies use different formats. No single company "owns" DVD and both technologies have their "champions".
DVD-R/RW was developed by Pioneer. Based on CD-RW technology, it uses a similar pitch of the helix, mark length of the 'burn' for data, and rotation control. DVD-R/RW is supported by the DVD Forum, an industry-wide group of hardware and software developers, and computer peripheral manufacturers. The DVD-R format has been standardized in ECMA-279 by the Forum, but this is a private standard, not an 'industry' ISO standard like the CD-R/RW Red Book or Orange Book standard.
DVD+R/RW is also based on CD-RW technology. DVD+R/RW is supported by Sony, Philips, HP, Dell, Ricoh, Yamaha, and others, and has recently been endorsed by Microsoft. DVD+R/RW is not supported by the DVD Forum, but the Forum has no power to set industry standards, so it becomes a market-driven issue"[/tt]
also wirklich zur norm ist noch keins geworden.
[tt]So which format should I invest in?
The battle between the 'official' -R/RW and rogue +R/RW formats is far from over. Unless all you're going to be doing is burning data, we wouldn't recommend a DVD-RAM drive, especially as the discs can generally only be read by other DVD-RAM drives. Sony's had a reasonable amount of success with its DRU-500A drive, which records both - and + DVD media, although whether that's a model that future drives will copy is a little uncertain at the moment.
In pure technical terms, DVD+R/RW has advantages over DVD-R/RW, but as with anything in IT, it's not always the best solution that wins out in the end.[/tt] aus http://www.zdnet.com.au/reviews/computer…20271788,00.htm
[tt]Wird DVD+ zum Standard?
(Hüseyin) Vielleicht kann man diese Frage in naher Zukunft wirklich beantworten. Noch kämpfen die Hersteller beider Standards um die Marktführerschaft. Nach dem Beitritt von Microsoft in die DVD+ Allianz liegen nun die Vorteile klar auf der Seite dieses Standards.
Zur Auswahl stehen zur Zeit DVD-Plus oder DVD-Minus Brenner und wer auf Nummer sicher gehen möchte, setzt auf Multi-Brenner die beiden Standards unterstützen. Für User die einen DVD Minus Brenner besitzen bedeutet das nicht das Ende. Selbst, wenn sich der DVD+ Standard durchsetzen sollte, wird es sicherlich noch eine zeitlang entsprechende Medien auch für den anderen Standard geben.
Zwar spielt mit Microsoft nun ein großer Player in diesem Segment mit aber es stellt sich die Frage, wie schnell sich die DVD+ als Standard etabliert. Sicherlich wird Microsoft dabei eine sehr wichtige und nicht gerade unerhebliche Rolle spielen. Die Integration des Standards in den Media Player könnte schon sehr viel bewirken. Neben Microsoft gehören auch Dell, Hewlett-Packard, Mitsubishi, Philips, Ricoh, Sony, Thomson und Yamaha dieser Allianz an.
Fazit:
Zur Zeit spielt es noch keine Rolle, was für einen DVD Brenner man sich kauft. Schließlich werden die gebrannten Rohlinge beider Standards überwiegend von allen Player ausgelesen, aber mit dem Eintritt von Microsoft könnte sich das bald ändern. Noch sind DVD- Rohlinge ein Stück günstiger als ihre Konkurrenz, aber die Preise haben sich in den vergangenen Monaten sehr stark angenähert und sollte sich DVD+ durchsetzen, wird es sicherlich schwer werden noch Hersteller zu finden, die DVD- Rohlinge ausliefern. Entscheidend wird sein wie Microsoft die DVD+ vorantreiben wird.[/tt] aus http://www1.giga.de/storie_u4/0,3202,54052,00.html
wenn ich mir dir namen ansehen, dann denke ich mir pioneer steht bald alleine da ;)
noid
Re: DVD Brenner
vendredi 2 mai 2003, 11:47
Fazit:
wenn ich mir dir namen ansehen, dann denke ich mir pioneer steht bald alleine da ;) - im moment aber wie alle sagen egal.
@Dino : wo hast du die information mit dem dvd-logo her ? die konnte ich nirgends finden.
noch ne idee : es gibt auf den dvds flags die beim brennen auf gewisse werte gesetzt werden. beim nec stehen die per default auf dvd-rom, in einigen foren stand, dass soll die kompatibilität verbessern.
2of11
Re: DVD Brenner
vendredi 2 mai 2003, 21:49
Ich habe mir den NEC ND 1100(A) gekauft..... gefällt mir soweit sehr gut, obwohl ich zum Backupen schon viele Rohlinge brauche.... mehr (bei einem Stückpreis von 3,70 bei EBay) als der Brenner gekostet hat... aber egal :P Ein Streamer wäre noch teurer gewesen und diese Daten werden einmal gesichert und müssen danach nie wieder verändert werden...
Das Gerät hat in diversen Tests auch gut-sehr gut abgeschnitten und ist halt sehr günstig zu kriegen!
* Hi! I'm a signature virus! Copy me into your ~/.signature to help me spread! * Zu allem bereit, zu nichts zu gebrauchen :D
noid
Re: DVD Brenner
samedi 3 mai 2003, 00:14
Citation de "2of11"
das sind dann aber markendinger oder ?
2of11
Re: DVD Brenner
samedi 3 mai 2003, 11:50
Jo... Verbatim 4x
Dino
Re: DVD Brenner
samedi 3 mai 2003, 18:37
@Noid: ich lese c`t, und zitiere nicht irgendeine Hardwareseite ;) DVD -R und DVD-RW IST Standard, weil das DVD-Konsortium ihn so abgesegnet hat. Das Sony und einige andere keine Lust Lizenzgebühren zu zahlen, wollten lieber selbst abkasieren: DVD +R war gebohren.
Dino
