• 14.10.2026, 21:40
creekin
Freitag, 24. Dezember 2010, 02:20
:thumbsup:
Looking good mate,
love the new feet.
looks like you need to spend some more $$s though (me too)
DAMN YOU SHOGGY!!! :D
slotrod
Dienstag, 28. Dezember 2010, 23:02
Hey case modders check this out. New Modders reference tool from MNPCTECH. will help you with about anything :D :thumbup:
slotrod
Mittwoch, 5. Januar 2011, 17:21
Who is making them for you.
(From Shoggy: You replied to a Spam-Bot. I did not remove your reply to avoid confusion)
slotrod
Montag, 31. Januar 2011, 06:04
Finaly had a cjhance to get some things done. I added tint to my pumps and res to match build.
I also added carbon to front bezel I think it gives it a cleaner look.
Uploaded with ImageShack.us
Morpheuzz
Montag, 31. Januar 2011, 11:00
nice pump and res you had. :)
how you maked it black?
slotrod
Montag, 31. Januar 2011, 15:07
I used 80% Automotive window tint. you can get this at your auto parts store. DO NOT USE anything but water to install it. The recommended solution they sell will affect your acrylic. it is a slow process because you must work out the air bubbles as you go.
If you are not familiar with the product it is a very thin piece. of tinted sheet that you lay over the window. it has self adhesive on the back that is invisible.
Morpheuzz
Montag, 31. Januar 2011, 17:13
ahh oke thx
