• 13.10.2026, 12:39
Morpheuzz
Freitag, 22. Oktober 2010, 21:21
looks nice.
you will make all tubes with this black sleeve? or only this one?
hobbes_dmS
Samstag, 23. Oktober 2010, 01:33
very nice and (especially) very clean.
my "projects" never look that clean ;)
slotrod
Samstag, 23. Oktober 2010, 04:30
Yes all the tubes in the build will be covered with sleeve it has a clean mechanical look that I like.
Thanks Hobbes for the comment you just gotta take your time and plan a liittle.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »slotrod« (23. Oktober 2010, 04:32)
smee
Samstag, 23. Oktober 2010, 15:26
Nice one slotrod,very nice 8)
slotrod
Samstag, 23. Oktober 2010, 17:10
Thankyou for the nice comments My LCD plate is finished now off to be anodized black
Uploaded with ImageShack.us
slotrod
Samstag, 23. Oktober 2010, 21:30
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »slotrod« (23. Oktober 2010, 21:32)
smee
Samstag, 23. Oktober 2010, 21:42
Nice one slotrod,you got some nice goodies there 8o
slotrod
Montag, 25. Oktober 2010, 21:42
Thankyou Smee I will be updating some nore later ib the week need to get something done 8o
Morpheuzz
Montag, 25. Oktober 2010, 23:42
it looks very well.
nice projekt :)
slotrod
Freitag, 29. Oktober 2010, 05:35
Mid shelf still needs wet sanded cleared and polished
slotrod
Freitag, 5. November 2010, 05:47
I added a power supply extender to give the build a little more room for a cleaner look.
slotrod
Freitag, 12. November 2010, 06:14
UPDATES
Morpheuzz
Freitag, 12. November 2010, 14:51
nice tubing on the board
what you mean with " power supply extender " ?
slotrod
Freitag, 12. November 2010, 17:53
Its a alum. box made by Lain Li that attaches to the back of the case allowing you to push the power supply out the back about 60mm. This allows for more room in the case.
slotrod
Mittwoch, 17. November 2010, 05:56
Frame now painted Dark metallic Charcoal Grey,
slotrod
Sonntag, 28. November 2010, 07:10
Morpheuzz
Sonntag, 28. November 2010, 16:34
it looks very good,
but i think it looks better when the front have one color ...
Seppel-2k3
Sonntag, 28. November 2010, 18:08
in my oppinion the radiator grills look real cheap, why didnt u use some grills from aqua computer and paint them in the same color of your frame or in black
slotrod
Sonntag, 28. November 2010, 22:13
I agree with the one color i have already removed the plates and painted them black this morning. The rad grills are not cheap They are 3/16 thick billet alum. with 360 degree centers that turn to where you want them. anodized black.
slotrod
Donnerstag, 23. Dezember 2010, 05:48
