Du bist nicht angemeldet.
Goetz
Goetz
Goetz
& I can only speak from personal experience for my particular systems set-ups e.t.c. I have run my 800D twin loop set-up for nearly three years now with many different rads/fans set-ups & taking pretty precise temp/noise & dust measurements e.t.c..
Goetz
Thanks for the info Namron, I'll be redoing my loop in my computer to fit the AC 5 water block and will give it a try.
With your setup, where do you measure the ambient room temp? Is it better to put a sensor on the bottom, top or back of the case?
Also what kind of dust covers do you use?
Goetz
Goetz
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Goetz« (27. Juli 2012, 07:27)
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Namron« (27. Juli 2012, 13:37)
