• 12.10.2026, 17:19
pegleg
Need help, to know what parts i need to hook up my six fans to the aquaero 5 xt
Donnerstag, 11. Oktober 2012, 19:29
i already have 2 aquastream xt pumps but only hooking up one for now , and Aquacomputer G1/4 Flow Meter Sensor Block USB Version (53129) I have 2 inline temp sensors,and will be buying the aquaero 5 xt,what else do i need to control my 6 fans with the aquaero 5 xt.will i need the Aquacomputer USB Poweradjust 2 - Ultra Version (53083) so i can control the 2 other fans on my rad? need help thanks to all that give me feed back.
Freitag, 12. Oktober 2012, 05:13
You don´t need Poweradjust 2, you can use y-cable
Aquabuß: AE5 Aquabuß high then this Y-4PINs andthis 4PINs to the Flow Meter
on the second connection of this Y-4PINs this Y-34PINs and two of the 3PINs to the AS xt´s
Or you can use 2 of this Y-34PINs and 3 of the 3PINs then Flow Meter need to be always USBconnected for power.
PS: AS XT observance 6.6
Dieser Beitrag wurde bereits 4 mal editiert, zuletzt von »EnigmaG« (12. Oktober 2012, 14:52)
pegleg
thanks again Enigma
Samstag, 13. Oktober 2012, 07:42
thanks is there a site in the states that will have these connections?so on the 4 fan hook ups on the aquaero 5 xt i can just use y pins to hook up 6 fans on the 4 fan hook up?
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »pegleg« (13. Oktober 2012, 07:50)
Samstag, 13. Oktober 2012, 11:10
Yes, up to 19,8 Watt(1,65A12V) each one
pegleg
Samstag, 13. Oktober 2012, 19:07
ok thanks very much ,but i hope i can find a place here in the state that will have them connections.
Montag, 15. Oktober 2012, 16:56
You can also order the cables from us. They easily fit into an envelope so shipping will be inexpensive.
