• 10.10.2026, 04:24
AndreasSWE
My Farbwerk only displays blue
Dienstag, 5. Mai 2015, 18:13
Hello.
I just got my last pieces to connect up my farbwerk and get some lights. I have the farbwerk USB version, standard LED strips and the IP65 connector Cable(mistake in the order). Now when I connect it up it only shines blue. I have tried changing it in the aquasuite program. I can turn down the brightness and make it darker or not shining at all, but I can not get it to show any other color than blue. Anybody else had this problem? What should I do? BTW I am using windows8.1 if that matters.
I made a clip that I put on Youtube that shows what it looks like. Here. https://www.youtube.com/watch?v=PT8njKxWaQg
regards
/Andreas
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »AndreasSWE« (5. Mai 2015, 19:36)
Mittwoch, 6. Mai 2015, 13:56
If you want us to view your YouTube video, you should put it in a public forum, not one we have to log into. :)
Your best course of action may be to contact support@aqua-computer.de
AndreasSWE
Mittwoch, 6. Mai 2015, 18:05
Well it is not much to see really, just blue... But now I changed the settings for it. Thank you for noticing.
