• 05.10.2026, 17:49
Nameless101
Aquaero 6LT and D5 aquabus
Samstag, 21. Januar 2017, 07:47
Hello,
I recently built my system and got everything up and running with the Aquaero. However, at the moment I have my D5 (USB/aquabus) connected through USB. I have tried connecting it via Aquabus (4pin/high), but when I do so, it shuts off the Aquaero, so that it no longer sphows up in Windows and my fans, which are also hooked up to the Aquaero, start blaring at full speed. What's going wrong?
Samstag, 21. Januar 2017, 16:52
The fans go to 100% because the aquabus connection is apparently disabling the aquaero.
Most likely reason is the aquabus connection.
Also, do NOT connect USB, aquabus or power connectors to the aquaero while it is powered up..
