• 29.11.2026, 08:12
Donnerstag, 12. April 2018, 01:40
Dear all
My device update software and firmware after
Not connected MPS
please help me
Thanks All
alexchan0829 has attached the following files:
MPS appears connected by aquabus.
MPS appears not connected by USB.
Are you using a USB hub?
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (12. April 2018, 01:42)
alexchan0829
Donnerstag, 12. April 2018, 16:38
Yes I have used USB hub
Freitag, 13. April 2018, 00:14
Sometimes a USB hub introduces a problem.
It may be useful to move one of the MPS unit USB cables from the hub and connect it direct to a motherboard USB port to see if it shows that way.
alexchan0829
Freitag, 13. April 2018, 14:14
感謝您的幫助和回复
Freitag, 13. April 2018, 14:29
感謝您的幫助和回复
"Thanks for your help and reply"
You are welcome, hope it helped.
annihilation
Freitag, 11. Mai 2018, 14:58
I have one of these flow sensors: https://shop.aquacomputer.de/product_inf…roducts_id=2294
How do I go about getting this updated? It is currently showing up under Aquabus but says "The device has no USB connection to is not recognized by the system" and then Remove device from aquasuite.
Any ideas?
GTXJackBauer
Freitag, 11. Mai 2018, 16:20
Any ideas?
There is a proprietary cable that you need to purchase since it's sold separately (unfortunately) and plug it into the Flow Header behind the AQ. Once you've done that, you can check and is if it's working under the Aquaero tab ---> Sensors tab ---> Flow Sensors. Once there, you should be able to choose your flow meter.
This particular flow meter doesn't need any firmware updates. It's basically a plug n play flow meter. That's not to be said about the other flow meters they sell that need a Aquabus or USB connection which then do need to be updated via firmware.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »GTXJackBauer« (11. Mai 2018, 16:22)
annihilation
Freitag, 11. Mai 2018, 16:27
Interesting. It stopped working since the update which is why I was asking. I will check the connections.
Montag, 14. Mai 2018, 15:48
Any ideas?
Are you sure the linked one is really your device?
The device in your link has no aquabus and no firmware. It cannot be updated.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »wpuser« (14. Mai 2018, 15:49)
CoAff
Donnerstag, 24. Mai 2018, 02:08
Any ideas?
The linked device uses this: https://shop.aquacomputer.de/product_inf…nu67405to0tgogk to communicate.
nhorn1983
Donnerstag, 7. Juni 2018, 13:22
is it possible to get an update on the software on the kryos kuplex block. i just installed my ryzen 2700x on an asus strix x470 gaming-f last night and the temp sensors are showing close to 100c this has to be a software bug as it was reading correctly the other day with an asrock x370 board. thank you
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »nhorn1983« (7. Juni 2018, 17:30)
Donnerstag, 14. Juni 2018, 15:03
You can try to reset the device back to the factory defaults but I doubt that this is a software related problem. It is much more likely that the temperature sensor got damaged by installing the CPU again. The sensor is very sensitive to pressure and will show weird values when it gets damaged.
What is the exact variant of the block that you have? Maybe you can exchange it yourself.
