• 29.11.2026, 09:18
bluechopa
5v addressable rgb led strips to RGBpx header?
Mittwoch, 16. Oktober 2019, 07:47
The headers of RGBpx are known to be 4pin, and the addressable rgb strips that are compatible with normal motherboards are known as 3pin - (+5, Data, NA, GND).
It's not compatible originally, but is there a way to fit it?
I want to connect Phanteks DIGITAL RGB NEON LED KIT to Quadro, but I hope there is a way.
TigerFire13
Mittwoch, 16. Oktober 2019, 14:15
There is, if you are handy with a soldering iron:
RGBpx wiring Diagram
bluechopa
Thank you for reply
Mittwoch, 16. Oktober 2019, 17:35
Unfortunately, I'm not used to soldering. So I'm going to make a conversion adapter for the rgbpx connector.
After searching the links and forums you told me, do I need to buy only Molex 151340406? Another forum I searched for told me to buy a Molex 51047-0400 connector and make a cable, but I don't know what's the right way to go.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »bluechopa« (16. Oktober 2019, 17:37)
TigerFire13
Donnerstag, 17. Oktober 2019, 14:21
I'm sorry, but I won't be able to offer much help on the connector identification.
I think the RGBpx connector has a radius on both upper corners, similar to usb microB. The molex part #'s you found don't appear to have this feature, but I could definitely be mistaken.
I'm excited to see your finished result, an adapter made from the proper ends with crimped cables would definitely be the better way to go, and would look a lot cleaner than the heatshrinked adapters I made for my thermaltake and phanteks gear.
bluechopa
Thanks a lot
Donnerstag, 17. Oktober 2019, 16:45
