• 03.10.2026, 22:48
Phoenix92
Aquaero 6XT RGB Header
Dienstag, 14. April 2020, 18:43
So I have an aquaero 6 xt and have been using it for quite a while running an rgb led illumination module (part no 34930) off the rgb header on the aquaero to the top of my res to illuminate it. My question is as these are run by 4 pin headers can I run a second one with a pwm splitter? Obviously they'd both show the same colour but I'd like to use one for the aquacomputer filter to illuminate it.
Mittwoch, 15. April 2020, 07:10
you can only connect one RGB led, when you use a y cable (or splitter) to connect more leds you can damage the output.
