• 14.11.2026, 19:29
RGBpx PicoBlade cable PSA
Donnerstag, 30. Juli 2020, 16:53
I erroneously assumed (yes, that error) the aquacomputer RGBpx PicoBlade cable pin-out followed the Molex PicoBlade off-the-shelf cable assemblies.
They do NOT!
The aquacomputer RGBpx connectors are inverted, the Molex are not. PicoBlade_Cable.jpg
It would have been nice to have additional cable options, but not to be.
k2viper
Donnerstag, 30. Juli 2020, 16:56
AQ RGBpx cables are JST 1,25mm 4-pin connectors available via aliexpress and wide range of DIY electronics stores.
»k2viper« hat folgende Datei angehängt:
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »k2viper« (30. Juli 2020, 16:59)
Donnerstag, 30. Juli 2020, 18:14
I made the post so others would not fall to the same folly as did I.
Due to a slight case of hand tremors, self crimping would not be for me, but I could easily build a cable with 2 housings and 4 same length pre-crimped leads from the selection offered. Just be sure to get the pin-out correct.
