• 14.11.2026, 12:04
tomfassnidge
Quadro alarm state
Samstag, 5. September 2020, 12:31
My quadro's fan channel 3 has been in an alarm state since I accidentally plugged in a ddc PWM connector which was wired incorrectly.
The message on the fan page states "Alarm: short circuit, fan output deactivated" - is there a way to deactivate this alarm?
There is nothing currently plugged into that channel - I've tried plugging in other (correctly wired) 4-pin connectors to clear the alarm to no avail.
Have I damaged something?
Thanks
Samstag, 5. September 2020, 15:31
i think your fan output is defect.
tomfassnidge
Sonntag, 6. September 2020, 11:10
Ok.
It was working fine before - I had a fan running from it.
There's no way to try to "reset" the alarm state?
tomfassnidge
Montag, 7. September 2020, 20:37
Just to update that the issue seems to have cleared itself - turned my pc on this evening and no alarm state.
I don't recall doing anything that would have done this - certainly not intentionally.
Dienstag, 8. September 2020, 02:10
The snippet below is from the aquaero manual. Perhaps the protection circuitry for the quadro is similar, and having powered your computer down allowed the amplifier to reset.
aquaero 6: Maximum current is 2.5 A per output independent of output voltage, resulting in a maximum power of 30 W at 12 V. Outputs will be switched off if amplifier temperatures reach a critical level and will automatically be reactivated when cooled down. If an output current of 3 A is exceeded, the output will be permanently disabled. To reactivate the output, the aquaero (or the complete PC) has to be disconnected from power for a short period of time. The fan outputs are short-circuit proof.
tomfassnidge
Dienstag, 8. September 2020, 17:54
I suspect that's exactly what happened.
