• 12.11.2026, 19:59
alex75
OCTO + D5 NEXT
Samstag, 12. September 2020, 18:11
Hello
i have an Octo and a D5 NEXT pump, in Aquasuite can't choose the D5 water temp as a data source for controlling fans.. is it possible ?
Thanks
alex75
RE: OCTO + D5 NEXT
Sonntag, 13. September 2020, 12:12
Hello
Thanks
Ok i figured it out..
Cheers
lazer-hawkuk
Montag, 8. Januar 2024, 19:43
i know it was a long time ago but what did you do i need todo the same.
thanks
nevermind found it you you goto sensors and click soft sensor 1 then choose the source as d5 next temp , so now i can control the octo with a fan curve
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »lazer-hawkuk« (8. Januar 2024, 21:00)
