• 28.09.2026, 20:12
brandofriva
RGB Twinkle Effect / Custom Effects
Dienstag, 22. Dezember 2020, 23:27
Looking for an effect similar to Razor Chroma's Starlight effect (random twinkle on LEDs). Or is there some way to do a custom effect to achieve this?
brandofriva
Montag, 28. Dezember 2020, 18:43
No-one have any ideas on how to achieve this effect?
Its just great as it will look good/consistent across any length of strip.
Montag, 28. Dezember 2020, 19:01
In farbwerk 360 / nano we have different effects like this,... you have to try out what konfiguration for you ist the best,
Every effect can be adjusted in many ways.
brandofriva
Montag, 28. Dezember 2020, 19:10
Are the effects on the Farbwerk 360 different to the Octo?
Tasky
Montag, 28. Dezember 2020, 19:18
I generally find the Farbwerk series has all the same effects as everything else, plus seven or eight extra ones that are only available on Farbwerk devices.
brandofriva
Montag, 28. Dezember 2020, 19:38
Thanks very much! I have a Farbwerk 360 on backorder from a local store. Hoping it supports this :)
