• 13.10.2026, 02:32
PiotrMKG
Repacing thermal pads in rtx 3090 strix active backplate
Freitag, 12. März 2021, 14:26
Hello,
I would like to replace original Kingbali 9902 Series Thermal Conductive Pad with gelid ones. Thin pads are 1mm but thicker ones are 1.8mm so I have to decide if I should go with 1.5mm or 2mm ones. Thanks for help.
Piotr
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »PiotrMKG« (25. März 2021, 00:23)
PiotrMKG
Montag, 15. März 2021, 14:46
Can someone from AQ (maybe Shoggy) tell me, what are designed clearances between RAM, PCB and other places where thermalpads are used and backplate?
Montag, 15. März 2021, 16:03
Were this me, I would opt for the 2mm version.
There is most probably 0.2mm of compression available in the 2mm thermal pad, but if the 1.5mm thermal doesn't make contact, you have fail.
PiotrMKG
Montag, 15. März 2021, 18:01
There has to be 0.2mm compression, thermalpads have to have 10% of compression to make proper contact. 2mm thermalpad should be good for clearances of 1.4 to 1.8mm. 1mm should be good for gaps ranging from 0.45mm to 0.9mm
