• 03.10.2026, 02:31
emperorjj1
Aquasuite OCTO fan control
Samstag, 29. Mai 2021, 13:31
Hey guys, I currently have an older build and just replaced an NZXT x61 AIO and Grid+ V2 with a custom loop and OCTO. I wanted the ability to utilize liquid temp sensors for fan control. SO far so good but only 1 fan is PWM the rest are voltage regulated. These fans are currently either off or 100% on when using the OCTO. Can someone help me figure out how to swap between the PWM functionality to voltage regulation?
Samstag, 29. Mai 2021, 13:33
There is no switching option, the OCTO can only control PWM fans.
You can see it here
Quote: "All fan outputs are compatible to PWM fans with four pin connectors only and feature overload protection."
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Taubenhaucher« (29. Mai 2021, 13:36)
emperorjj1
Samstag, 29. Mai 2021, 16:51
You can see it here
OK thank you
