• 04.11.2026, 06:43
kensaundm31
OCTO Question re: Default Settings
Sonntag, 27. Juni 2021, 12:48
Hi. What is the default % for fans connected to the PWM of an OCTO when you first turn it on?
Its just I'll have 17 fans hooked up and if they're gonna blast at 100% until I can install windows I'd be better off hooking up the octo to my current pc just to set it up to a more reasonable speed..
Karsten Ravneng
RE: OCTO Question re: Default Settings
Sonntag, 27. Juni 2021, 22:22
Yes, the fans will go at 100% :)
kensaundm31
RE: RE: OCTO Question re: Default Settings
Montag, 28. Juni 2021, 15:18
Ah ok, think I'll have to edit that beforehand, thanks.
WinstonWoof
Dienstag, 29. Juni 2021, 21:41
you can change the default power level for if the software isnt working (such as on boot)
On the Fan page scroll down to the bottom under Fan Setup and change the Fallback Power % figure
