• 02.10.2026, 15:41
Ryan_F_Mercer
AquaComputerCmd.exe -- Serial Number Not Found
Mittwoch, 4. August 2021, 07:32
I'm trying to play around with overwriting outputs from command prompt in Windows 10, but it can't seem to find my device's serial number. I used the proper syntax and the serial number provided within Aquasuite and tried running command prompt as administrator, but it says "No device with serial [xxxx-xxxx] found." What am I doing wrong?
It's a Quadro.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Ryan_F_Mercer« (4. August 2021, 07:43)
Ryan_F_Mercer
Mittwoch, 4. August 2021, 07:52
Nevermind... looks like it doesn't work with the Quadro. Darn.
Mittwoch, 4. August 2021, 08:37
This tool is only for aquaero 5/6.
