• 29.11.2026, 04:35
tiggerlator
Vision connected to Octo by aquabus?
Montag, 17. Januar 2022, 17:28
Is it possible to connect my Aquacomputer vision to the Aquacomputer octo via aquabus?
Which flow sensors can i connect to the octo?
Thx
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »tiggerlator« (19. Januar 2022, 13:04)
I7 12700k - Asus Rog Strix z690-A WiFi D4 - TEAM GROUP 2X16GB DDR4 3600C16 - MSI RTX 3080 GAMING X TRIO 10GB - Crucial P5 Pro 500GB M.2 NVMe Gen4x4 - WD SN850 1TB M.2 NVME Gen4x4 x2- SanDisk 2TB SSD PLUS 2.5" - Corsair RM850X - Lian Li o11D XL - EK 360mm PE - EK 360mm XE - EK supremacy classic - Generic (GPU) - Ultitube 150 D5 - dell s2721dgfa 27" nano IPS 165hz Custom corsair PSU cables
Montag, 17. Januar 2022, 18:20
The Aquabus can only be used to connect devices to an Aquaero.
Directly you can connect the high flow 2 and LT to the OCTO, the high flow NEXT is connected via USB to the motherboard and is then visible in the Aquasuite.Oh wait, with this cable you can also connect the high flow NEXT directly to the OCTO.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Taubenhaucher« (17. Januar 2022, 18:25)
tiggerlator
Mittwoch, 19. Januar 2022, 13:06
Would the next not connect to the Vision via a aquabus cable, then both show up in aquasuite?
Mittwoch, 19. Januar 2022, 13:49
You connect both via USB to the motherboard.
tiggerlator
Donnerstag, 20. Januar 2022, 01:37
So the aquabus is only for connecting stuff to the aquero? not between other aqua stuff, ok i get it. Though i don't really see the point of it when there is USB.
Donnerstag, 20. Januar 2022, 02:51
I think Aqaubus is an older form of serial communication and has pretty much been replaced by USB connectivity. More recent products usually have USB but some of them still support Aquabus, but if you don't have an Aquaero I don't think you can use Aquabus. Check the owner's manuals to be sure.
Donnerstag, 20. Januar 2022, 04:52
Aquabus is useful for Unix systems, where the aquasuite is not supported, to allow communications between an aquaero & other devices (e.g. flow sensor).
Remayz
Donnerstag, 20. Januar 2022, 10:31
or when you want hardware support for virtual sensors through aquaero.. or want your loop not to depend on Aquasuite even under windows.
tiggerlator
Donnerstag, 27. Januar 2022, 02:25
My vision keeps losing the sensors? the only display on it that works is the H2o temp which is via the connected aquacomputer sensor via the visions onboard connector. The only way to get the other settings to show again is to restart the aquacomputer service or restart my PC. any reason for this? is it a software error?
Here are some pics of my vision sensor and display setup.
Also if i get an aquero 6, will my EK PWM D5 work ok with it, i heard there are problems with the PWM version.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »tiggerlator« (27. Januar 2022, 02:29)
z00mantwo
Donnerstag, 27. Januar 2022, 05:29
You can connect them with that cable, but the OCTO will not give a correct flow rate. It's about 3 times higher than actual. I have mine connected that way right now. Look at the options under the flow sensor on the OCTO. It does not have a drop down option for the high flow NEXT.
Remayz
Donnerstag, 27. Januar 2022, 09:10
you have to use the high flow in the drop down list
Feature Request: Select high flow NEXT under flow sensor in OCTO
z00mantwo
Donnerstag, 27. Januar 2022, 14:07
When I try and select "Aqua Computer high flow (53068 )" as the "Sensor Type" I get a value of 29.89 l/m on the OCTO. The high flow NEXT says the flow is 2.57 l/m. Using another standalone flow meter I get a 2.6 l/m value so the high flow NEXT appears to be correct and accurate.
Donnerstag, 27. Januar 2022, 15:58
You have to configure the output signal in the High Flow NEXT!
z00mantwo
Donnerstag, 27. Januar 2022, 16:45
Thanks! Found the option under "Alarms" "Signal out out" never thought to look under there.
