• 02.10.2026, 07:30
aveamurechi
Connecting a GPU waterblock to the backplate
Donnerstag, 2. Juni 2022, 14:04
Hey
I'm looking to buy an 6800XT reference card and then water cool it with:
Backplate für kryographics NEXT RX 6800 / RX 6900, aktiv XCS (aquacomputer.de)
and
kryographics NEXT RX 6800 / RX 6900 vernickelte Ausführung (aquacomputer.de)
I'm unclear however about the way that the block and backplate would connect to each other. The connection to the tubing of each of the 2 seems to interfere/conflict with the connections of the other one. I looked at the manuals for both, and there seems to be no mention of this topic.
Therefore my question is:
- how would I connect the tubing from the backplate to the waterblock? is there an additional piece of gear I need to order? could you point me to which one (maybe some special fitting?, or just regular fittings?)?
Many thanks,
Andrei
Remayz
Donnerstag, 2. Juni 2022, 14:08
the backplate shop page says :
The back plate comes with a connection terminal that replaces the terminal originally installed to the kryographics water block
So i assume you'd have to remove the manifold from the waterblock and use the one that comes with the backplate.
cptninc
Donnerstag, 2. Juni 2022, 14:17
The active backplate comes with a new terminal. You remove the one that the block comes with (three screws) and replace it with the one that the backplate comes with,
aveamurechi
Donnerstag, 2. Juni 2022, 21:34
Clear. Thanks
