• 05.11.2026, 08:49
spyroot
CPU_FAN header
Donnerstag, 27. Juli 2023, 14:15
Hi Folks,
I'm using a server motherboard, which doesn't like when the CPU header disconnects. For now, I plug the
fan to make it happy is there any way to connect D5 next or Octo to CPU_FAN header.
For example, if the temperature sensor fails inside D5 next. The pump has no signal
about CPU temperature; hence I'm confused about the fallback here.
Kind Regards,
Thank you
Donnerstag, 27. Juli 2023, 14:31
Unfortunately, this is not possible. The devices are not able to generate a speed signal.
If a sensor source is missing or a sensor is defective, the controller goes to 100% power.
Tasky
Samstag, 29. Juli 2023, 04:18
Depending on the board manufacturer, you may be able to disable the CPU_Fan warning in the BIOS.
The D5 NEXT interfaces with teh motherboard via USB, so you may be able to set something up using the CPU Temp (via HWInfo) as a software sensor.
