• 22.11.2026, 20:30
Roburt88
Ampinel OLED screen turns off when idle, but never turns back on automatically.
Donnerstag, 10. September 2026, 01:13
Hi! I just installed my Ampinel and I've found that after a couple minutes idle the OLED screen turns off. The screen turns back on if I open aquasuite or click the button on the Ampinel, but it doesn't turn back on automatically if the GPU load increases significantly (like when you play a game). Is this normal behavior? I just want to make sure the unit is working as intended. Thanks!
Donnerstag, 10. September 2026, 07:39
this is correct. Idle means "no button is pressed", not idle load.
Roburt88
Freitag, 11. September 2026, 07:09
Good to know, thank you!
huntercrane69
Montag, 14. September 2026, 00:57
So "idle" basically means "nobody touched the button". That explains it, but I can definitely see why people would read it as GPU idle. Slightly evil wording there
