• 22.11.2026, 00:17
coolkwc
Ampinel 12V2x6 Connector Loose
Freitag, 11. September 2026, 05:28
Hi, i'm the 1st batch user of Ampinel which delivered 3 weeks after it launched.
It is used with my Astral 5090 and i notice some issue on the fitment after 6 months of usage.
My card is watercooled and veritical mounted, means the Ampinel is lay horizontal with screen face up.
The ampinel connector with GPU become 'loose' by itself when i use my hand to slightly touch the device up and down, and it slightly 'sink' when i withdraw my hand.
and i'm 100% sure it was tight fit and hanging straight up without any free play/move at all during new.
Did anyone of your encounter similar issue? I don't know whether is the connector on the ampinel or GPU is degraded.
Aurelius
Montag, 26. Oktober 2026, 00:25
I have the same issue. Every couple of weeks or months I start to get alarms on one of the Ampinel units. Have gotten alarms on both now. The only way to resolve it is to open the case, and to push the Ampinel unit tight in my GPU again. I also tighten the 12VHPR cable on the back of the Ampinel. After that, no more weak sense pins and I have no problems for weeks or months. But problem keeps coming back. Any tips?
»Aurelius« hat folgende Datei angehängt:
  • Aurum.jpeg (150,85 kB - 62 mal heruntergeladen - zuletzt: Gestern, 20:30)
SgtSixpack
Dienstag, 27. Oktober 2026, 14:22
Any tips?
I personally would zip tie it tight. As for tips, I saw that hardwareunboxed on youtube had a 5090 cable problem. It was on the PSU cable end, make sure that is tight too.
