• 29.11.2026, 05:01
edboswell
flow sensor stuff
Montag, 9. Januar 2006, 01:41
hi what should the default calibration value in impulses/liter be .. and why should i need to change it (would does it do)
thanks in advance ed
Re: flow sensor stuff
Montag, 9. Januar 2006, 02:01
Default is 519 Imp/L and you only need to change it if you use an other sensor than the sensor from AC or if you have modified it.
edboswell
Montag, 9. Januar 2006, 02:08
ok thanks :)
edboswell
Montag, 9. Januar 2006, 02:12
btw my xt now makes my flow rate 45 l/h instead of 20 with the pro :o
x-stars
Montag, 9. Januar 2006, 12:19
No, according to the manual at digmesa and the aquasuite-standard it's 509 :P.
You can drill your sensor input to get the 3,3mm-Input bigger - then you should chage in and out and fix the Impulse/L to 256 (so you don't need to check your sensor manually, 'cause the output is 5,6mm and 256 the official Digmesa-value). But keep in mind: To my and the experience of some other a drilled sensor doesn't rule at all - I have the same flow-rate as before (in truth, it's a little less :P).
Top_Nurse
Montag, 9. Januar 2006, 21:38
Something is not right if you increase the surface area of the intake 40 percent and get less flow. ??? Did you do a quanitative measurement to make sure you are getting less flow or did you just depend on what the Aquaero reports? Perhaps the IPL is not correct.
x-stars
Dienstag, 10. Januar 2006, 00:02
It wasen't so much - such like one ore two liters less (in the 45L/h-area), so it could be in the measurement-tolerance (but I didn't check the value with something like a ten L-Bucket and a stopwatch, just took the digmesa-value).
Apart from that: The flow is good enough and if it breaks down, the aquaero will detect it (and I don't care if it rescues the PC because the flow is at 10,00 or at 20,00 - it's enough if it will rescue it ;D).
