• 12.11.2026, 22:22
Paskee
Aqua computer service stops erraticaly
Mittwoch, 3. Mai 2023, 15:28
Hello there !
Thank you in advance for your held on this one.
Since updating to the second-to last version x67 (now running x68 and this is the same), for which I had to update my dotNet version (without problem it seems since I could install The x67 version), the Aqua computer service stops now and then for no apparent reason, but at the very least once a day.
When I try to start the service manually, windows return the "1035 error: The service could not be started in a timely manner".
My only way to solve this so far is to reinstall the whole Aqua suite, restart and then reset the playground settings.
Do you have any thought on how I could solve this?
Thanks in adance,
Regards
Paskee
Mittwoch, 10. Mai 2023, 20:04
Hello there,
Is there anyone that can help me? still no luck with this and now the service stops each time I start my computer, after rougly 10 minutes.
Does anyone have an older version of aquasuite (x.59) that I can try?
Regards,
P
