• 05.10.2026, 05:53
AP2
Aquaero 5 XT Bezel Dimensions?
Monday, June 4th 2012, 5:43am
does anyone know if these dimension are accurate for the aquaero 5 xt?
AP2 has attached the following image:
Monday, June 4th 2012, 9:44am
The general dimensions are OK but the front of the current XTs have been updated and the area of the IR diode has been slightly changed so you can not take this drawing as reference anymore.
AP2
Monday, June 4th 2012, 6:29pm
thanks Shoggy for the confirmation. How do i know if i have the updated faceplate? Also, is there a drawing with the correct dimensions?
Tuesday, June 5th 2012, 9:03am
I have no detailed drawing available.
The aquaeros have different order numbers. You will also find this number on the box of your aquaero. The one with the older front has the number 53089 while the newer one has the number 53125. The difference is also visible:
Current one (53125):
Old ones (both 53089):
You can easily spot the difference on the IR diode. The older ones have a separate hole there while the current one is integrated into the main cut-out.
AP2
Tuesday, June 5th 2012, 5:33pm
ok thanks shoggy! i purchased my aquaero 5 about 2 months ago from you guys. how do i get a new bezel and what are the benefits vs the old one.
thanks!
Wednesday, June 6th 2012, 11:02am
If you have no problems with touch control there are no benefits at all. If you only want to change it because of the looks you can purchase the new cover.
AP2
Wednesday, June 6th 2012, 11:50am
thanks for the speedy response! yeah, i have the sensitive key issue - only way i got it to stop clicking was turn the sensitivity down all the way and just use the remote. are the black ones in stock?
Monday, June 11th 2012, 12:09pm
The black covers are not in stock. I guess they will be back in around 2-3 weeks.
Similar threads
