• 13.10.2026, 23:52
pegleg
Need help, to know what parts i need to hook up my six fans to the aquaero 5 xt
Thursday, October 11th 2012, 7:29pm
i already have 2 aquastream xt pumps but only hooking up one for now , and Aquacomputer G1/4 Flow Meter Sensor Block USB Version (53129) I have 2 inline temp sensors,and will be buying the aquaero 5 xt,what else do i need to control my 6 fans with the aquaero 5 xt.will i need the Aquacomputer USB Poweradjust 2 - Ultra Version (53083) so i can control the 2 other fans on my rad? need help thanks to all that give me feed back.
Friday, October 12th 2012, 5:13am
You don´t need Poweradjust 2, you can use y-cable
Aquabuß: AE5 Aquabuß high then this Y-4PINs andthis 4PINs to the Flow Meter
on the second connection of this Y-4PINs this Y-34PINs and two of the 3PINs to the AS xt´s
Or you can use 2 of this Y-34PINs and 3 of the 3PINs then Flow Meter need to be always USBconnected for power.
PS: AS XT observance 6.6
This post has been edited 4 times, last edit by "EnigmaG" (Oct 12th 2012, 2:52pm)
pegleg
thanks again Enigma
Saturday, October 13th 2012, 7:42am
thanks is there a site in the states that will have these connections?so on the 4 fan hook ups on the aquaero 5 xt i can just use y pins to hook up 6 fans on the 4 fan hook up?
This post has been edited 2 times, last edit by "pegleg" (Oct 13th 2012, 7:50am)
Saturday, October 13th 2012, 11:10am
Yes, up to 19,8 Watt(1,65A12V) each one
pegleg
Saturday, October 13th 2012, 7:07pm
ok thanks very much ,but i hope i can find a place here in the state that will have them connections.
Monday, October 15th 2012, 4:56pm
You can also order the cables from us. They easily fit into an envelope so shipping will be inexpensive.
