• 18.11.2026, 15:11
frank anderson
PA2 disappeared after installing Aquasuite 2013 2
Tuesday, March 26th 2013, 6:04pm
Anyone else having this issue? I tried unplugging the computer from the power completely to let everything cold boot, still nothing. It was all there when I was using 2012 RC6 previously.
Thanks...
Tuesday, March 26th 2013, 6:18pm
Tomorrow we release a bugfix for the aquabus problem. The delivery of version 2013-2 is stopped.
frank anderson
Tuesday, March 26th 2013, 6:26pm
Thx Sebastian, will wait till tomorrow and update then.
Wednesday, March 27th 2013, 8:10am
The Bugfix is online.
We have deactivated the aquabus for some tests in the firmware 1029. But we have not enabled in the release version. Reload the aquasuite and install the new 1030 firmware.
We are sorry for the inconvenience.
mandrix
Wednesday, March 27th 2013, 11:00am
I'm still running the original 2013 AS software/firmware. Is it worth it at this point to install the newest software? Any firmware upgrades for the PA2's?
I missed 2013-2 altogether, fortunately.
frank anderson
Wednesday, March 27th 2013, 11:06am
Thanks, no worries, the fans and pumps that were connected to them were still running, just couldn't monitor them from Aquasuite, accidents happen.. Thanks for the quick follow up though, all is working now :)
Namron
Wednesday, March 27th 2013, 1:30pm
Yup!!..... All is now well again in the Nams world of Aquasuite :D .. Thanks for keeping us updated Sebastian & thanks to peoples that got things sorted so quickly... Nice one :thumbsup: ..
N.
marchitect
Wednesday, April 3rd 2013, 4:01am
My PA2's disappeared after the 2013-2 update. I upgraded to firmware 1030 for the Aquaero as well. I've also uninstalled and tried reinstalling the Aquasuite version 2013-2.
What should I do, go back to the beginning and try to set up each PA with the USB and set the address 50,51,52 and then hook up that PA2's to the Aquaero with the Aquabus?
All of my fan profiles are gone as well.
Also, when you say the bugfix is online, is that referring to 2013-2 software upgrade?
Wednesday, April 3rd 2013, 7:33am
2013-2 is the upgrade. (aquaero Firmware 1030)
mandrix
Wednesday, April 3rd 2013, 10:34am
Sebastian, it would be helpful if the Aquasuite versions were labeled as such, or at least a release date shown on the download page.
Wednesday, April 3rd 2013, 10:46am
in the download section is always the lastest version.
mandrix
Wednesday, April 3rd 2013, 10:57am
Numbered releases are good. :P
marchitect
Thursday, April 4th 2013, 2:06am
Regarding the main intention of my forum post: Should I go back to the beginning and try to set up each PA with the USB and set the address
marchitect
Tuesday, April 9th 2013, 4:24am
I decided to start over and disconnect all the PowerAdjust and Aquaero cables to try to get everything back online after the firmware update. It was such a hassle as it is such a tight fit when you have 3 PA's and an Aquaero linked in 2 5.25 drive bays. Anyway, I got it all to work again.
However, one thing that I didn't notice before in Aquasuite: Each PA has a RED 'X' through a USB icon. This looks like it is indicating an error, saying that the USB for each PA is not hooked up which I've always assumed was the correct install method. If this is the correct way to set up the PA's, why would a RED X be showing? This looks like something is wrong.
Is this indicator correct? Meaning is the RED X correct?
I've always assumed you only use the USB to PA for initial set up and setting the addresses (50,51, . . )
Also, when I look at the Aquaero, there is a faint red blinking light behind the factory sticker. It doesn't blink at the same rate. Sometimes is very fast and sometimes it is slower. Is this normal? What is this indicating?
marchitect
Aquasuite Red X and Red LED on Aquaero
Sunday, April 28th 2013, 8:44am
One thing that I didn't notice before in Aquasuite: Each PA has a RED 'X' through a USB icon. This looks like it is indicating an error, saying that the USB for each PA is not hooked up which I've always assumed was the correct install method. If this is the correct way to set up the PA's, why would a RED X be showing? This looks like something is wrong.
From previous post:
In Aquasuite: Each PA has a RED 'X' through a USB icon. This looks like
indicating?
Thanks
mandrix
Sunday, April 28th 2013, 11:28am
Right. Just delete the page since the PA2 now shows up as a fan header on the Aquaero if you've connected it via Aquabus.
marchitect
Monday, April 29th 2013, 4:34am
When you say 'just delete the page', what page are you referring to? I'm referring to the Overview page. I don't think you want to delete the overview page. The Poweradjusts, on this overview page, which have the Red X through the USB symbol do not have a delete page option. The only delete option is to delete the device.
Also, what is the story with the blinking red light hiding behind that Aquaero sticker? It's always blinking rather fast and the color is Red.
Thanks
mandrix
Monday, April 29th 2013, 11:49am
I'm talking about the PA2 page, what are you talking about?
marchitect
i'm referring to this
Tuesday, April 30th 2013, 5:55pm
See attached word document with a screen capture
marchitect has attached the following file:
  • Aquaero USB.pdf (129.05 kB - 562 times downloaded - Last download: Yesterday, 10:54pm)
mandrix
Tuesday, April 30th 2013, 7:07pm
Right. Once you have the PA2's connected to the Aquaero aquabus, then each PA2 should show up as another fan header in Aquasuite for the Aquaero. You no longer need the USB connection when the aquabus connection is used.
The software knows the USB is no longer connected, or necessary, and so the red X. If they are showing up as fan headers 5, 6, etc for the Aquaero then you can just delete those PA2 pages as they are no longer functional.
The only time you should need to reconnect the USB cable is when updating firmware.
