• 17.07.2026, 03:07
Kyle XY
Details on Aquaduct Mark V
Monday, April 13th 2015, 8:16pm
Hello,
I am interested in buying an Aquaduct 720 XT Mark V. It appears that two straight plug & cool fittings G 1/4 are already mounted onto the Aquaduct.
Should I be able to replace them by my own G1/4 connectors ? For example, I would like to replace them by such a part : http://www.docmicro.com/watercooling_emb…ickel_7767.html
due to the fact I am looking for a complete secured sytem and the Aquaduct will be rarely disconnected or moved.
Thanks in advance for your answer !
Kyle XY
Tuesday, April 14th 2015, 10:23pm
Mmmmh ? No answer ?
I mean, the original connectors are only just tightened onto the Aquaduct, i.e. they can be easily replaced by other ones, or do they have a specific assembly ?
Thanks a lot !
sircody01
Tuesday, April 14th 2015, 10:32pm
Maybe the exploded view from this forum post will help?
Welche Pumpe ist im Aquaduct 720?
InfoSeekerX
RE: Details on Aquaduct Mark V
Wednesday, April 15th 2015, 5:16pm
Hello,
I have an Aquaduct 360 XT MARK V, and yes, the two Plug & Cool inlet/outlet fittings at the base are G1/4 fittings that may be unscrewed and replaced with any G1/4 fitting you have.
Kyle XY
Wednesday, April 15th 2015, 10:07pm
Excellent ! Thank you for your answer !! :thumbup:
InfoSeekerX, for my information, what elements (radiators, blocks) did you have in your loop ?
This post has been edited 1 times, last edit by "Kyle XY" (Apr 15th 2015, 10:17pm)
InfoSeekerX
Thursday, April 16th 2015, 12:08am
Quoted
Currently I have an EKWB Monoblock for the MoBO & CPU & two EKWB on the video cards, and then two Aquacomputer D5 pumps on an EKWB dual top, placed inside an airplex GIGANT 1680 with aquaero 6 PRO, copper fins. (retired the 360)
This post has been edited 3 times, last edit by "InfoSeekerX" (Apr 16th 2015, 12:11am)
Kyle XY
Thursday, April 16th 2015, 7:31pm
Whooaa !! 8o
Are you able to do the concatenation of pumps on a same loop ?
A big question : Aquaduct seems to have aluminum elements. It seems not compatible with copper blocks. Am I right ? What are the advice from the Aquaduct designers ?
InfoSeekerX
Thursday, April 16th 2015, 8:58pm
Whooaa !! 8o
Yes you can... series or parrallel. I use the EK-D5 Dual TOP G1/4 CSQ - Acetal to run my dual D5s in series (Installation Manual)
For that discussion I recommend you contact support: support@aqua-computer.de
This post has been edited 1 times, last edit by "InfoSeekerX" (Apr 16th 2015, 9:04pm)
Kyle XY
Thursday, April 16th 2015, 9:45pm
I asked my question by e-mail but it could be answered on the forum in order to be helpful for all customers. :rolleyes:
Kyle XY
Friday, April 17th 2015, 5:44pm
I have another question, about the loop to be connected to Aquaduct.
How many elements can be connected to the Aquaduct (360 and 720 XT version) before needing an additional pump ? By the way, what would be your recommendation about any additional pump ?
InfoSeekerX
Friday, April 17th 2015, 10:41pm
With the water block load I listed above, I was getting 75 - 80 lph, and under regular load (browsing, etc) I was fine. But when I went into gaming mode, and both graphics cards & the CPU loaded up, the 360 was unable to dissipate the heat. A 720 should do twice the heat dissipation.
The beauty of the aquaducts are the all in one function of the build... if you added an external pump, it would require extra modding to get it into the aquaero 5 PRO. If you are comfortable with 75-80 lph, then you don't need a second pump if you have a similar setup. I went to 2 pumps because it was a custom build, and the second pump is a safety item in case one goes down.
This post has been edited 1 times, last edit by "InfoSeekerX" (Apr 17th 2015, 10:42pm)
Kyle XY
Saturday, April 18th 2015, 9:56am
In fact, my reasoning was based in terms of head loss.
Each block the water goes through generates a local head loss. My question was how many radiators and blocks can be in the watercooling loop with the Aquaduct before its pump has too much load to provide.
By the way, do Aquaduct 360 and 720 shear the same Eheim pump, which means 720 pump has higher load to provide than for 360 version ?
InfoSeekerX
Kyle XY
Sunday, April 19th 2015, 12:12pm
Looking in the forum with the German part and going through Google translator, even the translations were not featured by high quality :D , this is what I understood.
Aquaduct versions 360 and 720 share the same compact 600 Eheim pump, this latter being customized by Aquacomputer team.
Reference : Welche Pumpe ist im Aquaduct 720?
This post has been edited 1 times, last edit by "Kyle XY" (Apr 19th 2015, 12:17pm)
