• 25.11.2026, 03:28
MP7
Monday, April 27th 2015, 3:25pm
Hey Nam,
thx for replying. Yes, I have the one that came with the cables already.
So yeah I don't have to connect him with the mobo, since that 5pin connector will be already taken by the one form the Aquaero, I mean the flow meter only has to send the signal reading to the Aquaero and that's it I think. Like I said, you connect the usb connection only if you don't have an aquaero I guess. Or I got it wrong? On the aquaero you have 4 pins for "high" connector but the cable has 3 pins, so I actually need an "aquabus" cable with 4 pins?
This post has been edited 3 times, last edit by "MP7" (Apr 27th 2015, 3:30pm)
Namron
Monday, April 27th 2015, 3:35pm
Hey Namron,
Pretty much all the Aquaero add on's can be connected both via the Aquabus & the SB at the same time as some people prefer to do, but, Yes as you say you can just connect the add on using just the Aquabus high connection. Although some add ons do require that you set it's Aquabus number & this can only be done by the add on being connected via the USB first.
Nam...
MP7
Monday, April 27th 2015, 3:41pm
You're right, it's the high flow port on the aquaero
I found this on overclock.net, someone wrote :
Quoted
red is the 3-Pin flowmeter header for the non-usb flometer. You
connect the USB/Aquabus flowmeter to the High-Speed Aquabus Header
circled green. You can't connect from Aquabus => Fan Header!!!
The reason that the flowmeter you bought costs more is because of the
Aquabus/USB function. The cheaper one only has a 3Pin output which can
be connected to the flow header or the first fan header. The USB/Aquabus
version needs to be connected to the Aquabus, which is the whole
purpose of paying extra for it
Namron
Monday, April 27th 2015, 4:01pm
I thought you must have had the USB/Aquabus version of the flow meter by your description of the cables you said you had come with it :) ... & Yes you need to get thee 4 pin Aquabus cable if you want the full function of most Aquabus add ons, Although I think you will be ok just using the 3 pin Aquabus cable that came with the flow meter if you like :thumbsup: ...
Nam...
This post has been edited 1 times, last edit by "Namron" (Apr 27th 2015, 4:13pm)
MP7
Monday, April 27th 2015, 4:21pm
Yeah I will be ordering a lot of stuff from percormance pc's soon so 1 or 2 more cables won't be a problem, I will go bankrupt anyway with my new build :wacko:
Thx Nam
Namron
Monday, April 27th 2015, 8:34pm
Thx Nam
HaHa... Yup sure is an expensive hobby when you get into it & want to do it properly :D .... It never hurts to have a few cables spare I've always found. Look forward to seeing your build wherever you happen to post it up :thumbsup: ...
If you should need more info or a few guides on the Aquaero I have done a couple of guides e.t.c that you may find helpful or useful. It's on my own site I set up a while ago, But it needs updating & then some lol,.. I've not been to well these last few months & will get around to do tidying it up & updating it in the not too distant future when my health gets a wee bit better. Anyway if you fancy a read or want some info on the Aquaero e.t.c then give My Guides a quick look :) .. Although it mostly caters for the Aquaero 5 a lot of it is still very relevant to the Aquaero 6 e.t.c.... There is also a link to my site Guides on the Aquaero Owners Club Thread on "Overclock.net",, It's on the first post that Darlene put up..
Nam...
This post has been edited 1 times, last edit by "Namron" (Apr 27th 2015, 8:36pm)
MP7
Monday, April 27th 2015, 10:14pm
Wow some nice stuff there thx, I will take a look and read everything and try to absorb some knowledge and good advices from experienced people like you as I'm totally new to aquaero.
I will definitely post the new build, it will be something special, if you want to just take a look at my current build(don't mind the language lol, just look at the pictures..you know just like when you watch a porno mag), which is nothing special but the interesting fact is that the case is made by acrylic, the case itself is like a copy of a well known case but I decided to make it myself and in the end I think it came pretty good
This post has been edited 1 times, last edit by "MP7" (Apr 27th 2015, 10:15pm)
MP7
Wednesday, October 14th 2015, 8:24pm
Hello guys!
It may be a stupid question but I have to ask..on the high flow usb flow meter - do you have to connect the usb as well to a usb header on the mobo or just the 4 pin with an aquabus cable to let's say "high" input on the aquaero?
With the latter it doesnt recognize anything, although I havent installed windows yet so I haven't played with the aquasuite...
Jakusonfire
Thursday, October 15th 2015, 11:51am
The Aquabus cable only connects to the Aquabus high port on the aquaero.
You will need to connect the meter to your motherboard via the USB cable first. It will fit into the same internal USB port the aquaero is on. Use Aquasuite to set the meter to the correct type of mps device, set the priority to Aquabus, then the aquaero will be able to detect the meter as the right device after you disconnect all power from the system and restart.
MP7
Thursday, October 15th 2015, 3:07pm
Thank you Jakus, gonna try that right away! :)
MP7
Thursday, October 15th 2015, 4:44pm
Hmm things seem to be like before
So everything is set fine:
And this is exactly the same as it was before I hooked up the USB cable
Do I need to play with the aquabus address?
MP7
Thursday, October 15th 2015, 9:18pm
LOL never mind about that last question, that in the screenshot IS the actual flow !
And I didnt even need the USB to be connected, now when I remove the USB connection it still receives the flow, through the aquabus cable of course.
I mean I understand you would need to connect the USB at least to set it up correctly in aquasuite, just like you do with the farbwerk bluetooth when you have to connect it to USB for the first time to set external output and after that you can disconnect USB, but what puzzles me is that even when I didnt have USB connected (and never did before I tried it today) on the flow sensor it was showing the flow...
This post has been edited 1 times, last edit by "MP7" (Oct 15th 2015, 9:22pm)
Friday, October 16th 2015, 12:06am
Most likely you have only the one MPS device installed, and the default bus ID of 12 is not in conflict with any other MPS devices.
You would still need to use the USB connection to calibrate the unit, but it will show a flow rate without calibration.
MP7
Friday, October 16th 2015, 11:05am
Yes only one MPS device installed, and I even changed the address still working fine.
But do I have to calibrate it? isn't the default value of 169 imp/l pretty correct? I'm using standard 10mm inner diameter tubing
Friday, October 16th 2015, 4:09pm
If you have only 1 MPS device it can have any one of the four MPS Bus IDs assigned.
As to the calibration, I was speaking in general. In your case, as was the BUS ID default acceptable, so was the calibration default acceptable.
MP7
Friday, October 16th 2015, 11:01pm
Roger that. Thx
Everything is running fine now in my testing and tomorrow I plan to connect the D5 PWMs to the aquaero, I left 2 fan channels for the pump wires to come in. Right now I have only one pump connected to its power supply so I only have to connect the cable with PWM and RPM, I'm wondering if to set the output value first and then connect the pump live or do I have to shut down before connecting it I mean if it does even matter?
EDIT:
All done :)
This post has been edited 1 times, last edit by "MP7" (Oct 17th 2015, 4:45pm)
