• 31.10.2026, 17:12
OddsCrazyStuff
Does Aquaero/Fabwerk support all RGB LED strips?
Wednesday, December 21st 2016, 7:50pm
I'm thinking of picking up a side emitting RGB strip, as the case I'm building wont work with normal wide LED strips (not enough space in the width).
Can Aquaero 6/Fabwerk handle these type of strips: https://www.ledworldlighting.com/product…-5m-sv-12v-rgb/
Thursday, December 22nd 2016, 8:33am
Should work for the farbwerk if the LED strip uses the same pin assignment.
The aquaero can not handle LED strips! The RGB LED port is designed to power one RGB LED. If you connect a LED strip there it will overload and maybe damage the device.
OddsCrazyStuff
Thursday, December 22nd 2016, 6:29pm
Can this be used on Aquaero mounting holes: https://shop.aquacomputer.de/product_inf…q2gsr2r8j9vbssb ?
I'm asking because I'm getting a Parvum made that has mounting holes for 2 Aquaeroes, so it would be nice if I can just use the 2nd set of holes for 2-3 fabwerks (getting a case with led design in the panels, so need a lot of strips overall).
Also, is there any of the cables for Aquaero, Fabwerk and SPLITTY9 that are proprietary (cant be replace by standard cables)?
They will most likely all be in view, so need to find a way to get them all sleeved or buy sleeved versions.
This post has been edited 1 times, last edit by "OddsCrazyStuff" (Dec 22nd 2016, 8:19pm)
