• 29.11.2026, 06:16
Timstone
Shortening of lengthening LED strips
Sunday, March 5th 2017, 1:15pm
Hi all!
Is it possible to shorten a AQ LED strip (by cutting it in half for instance)?
Is it possible to connect say two 50 cm LED strips together?
Men may control the free world, but women control the boobs. Brent in Player vs. Player
Fieldrider
Sunday, March 5th 2017, 3:25pm
Yes, you can cut them on the contacts as seen here:
Klick me
For connection two stripes together, you could solder the contacts together or buy some conectors,like these for example:
Klick me
This is just an example, this one is for normal LED-Stripes, for RGB you need to have one with four contacts. And they come different shapes, there are also comnectors with short cables so that you could place them on the top and on the side of a PC case or there are 90° corner pieces or ven T-pieces.
You have to make sure that you connect them correctly, so if it's an RGB-LED Strip, then needs to be R to R, G to G and B to B of course
Timstone
Sunday, March 5th 2017, 4:30pm
Thanks for this wonderful answer! :thumbsup:
