• 29.09.2026, 15:22
spalex
Controlling DDC pumps using aquabus
Sunday, April 2nd 2017, 10:27am
Hi guys
I am new to this, but I seem to have figured it all out without any problems.
The only thing I need help with is controlling my pump speed using the aquero 6.
My pump is an EKWB DDC 3.2 pwm pump.
When it is connected to my motherboard it works fine, changes speeds.
But I have connected it to the aquabus high header on the aquero, and it just runs at full speed.
In the aquasuite software, nothing comes up when I click on pumps. Or when I click on Aquabus.
What am I doing wrong / forgetting?
Sunday, April 2nd 2017, 11:38am
Disconnect it NOW!
The aquabus is no PWM Controll connection. You can destroy your aquaero and your Pump.
GTXJackBauer
Sunday, April 2nd 2017, 12:58pm
Disconnect it NOW!
This.
Fieldrider
Sunday, April 2nd 2017, 5:15pm
And then, try to connect it to Fanport 1.
spalex
Monday, April 3rd 2017, 4:01pm
It's okay. I only had it connected for a short time before I realised it was not working.
I plugged it back into the motherboard header.
I will try to configure it using the fan connections on the aquero.
Thanks for the info guys
