• 13.10.2026, 22:33
jamesweishaar
Can an Aquaero 5 LT be used as a slave to Aquaero 6 XL or do I need a Aquaero 6 LT?
Monday, May 7th 2018, 4:33pm
I have an Aquaero 6 XL.
I would like to expand the number of fan channels from 4 to 8 by adding a slave device.
Since I own a version 6, do I need a 6 LT or can I buy a 5 LT? If I can buy a 5 LT for this is there any advantage in buying the 6 LT?
(A Splitty9 would increase the number of fans I could use but does not add channels. All the fans get the same PWM instructions and only one fan reports back to the controller it's RPM. - right?)
James
jamesweishaar
yes?
Tuesday, May 8th 2018, 5:24am
I don't like replying to myself but in case someone has the same question and looks at my post I would like them to have something.
I found this thread - "https://forum.aquacomputer.de/weitere-foren/english-forum/p1428274-problems-with-lt-as-a-slave/?highlight=slave#post1428274"
It's from a person who had a 6 XT and a slave 5 LT. He's having a problem but it's not from having different board numbers.
So I guess it's OK to have this configuration. :thumbup:
Tuesday, May 8th 2018, 7:51am
aquaero 5 has 4 channels with 1 PWM channel. "Maximum output power is 19.8 W (1.65 A at 12 V) for each channel."
aquaero 6 has 4 channels, all PWM. "Maximum current is 2.5 A per output independent of output voltage, resulting in a maximum power of 30 W at 12 V."
You can use a combination, even an aquaero 5 as master and an aquaero 6 as slave.
gr3if
Tuesday, May 8th 2018, 10:57am
5 and 6 can be used in any combination as master/slave.
jamesweishaar
Tuesday, May 8th 2018, 7:53pm
Thank you WPUSER and GR3IF!
I thought so but I really wanted someone with some experience to verify my guess.
The extra information about the PWM channels in the 5 and 6 is very useful WPUSER.
dang it.....I only need one more channel for what I am going to do but if I expand my plans again maybe I should get a 6 LT.
James :wacko:
jamesweishaar
Tuesday, May 8th 2018, 8:07pm
Are you sure about the PWM channel?
This document https://forum.aquacomputer.de/images-ac/aquaero_5_eng.pdf specifies "Output for PWM-fan" as "channel 4"
I guess that could mean 4 PWM signal split across 4 fan outputs but that is misleading.
EDITED - Never mind. I guess it's pretty obvious when you look at the 5 LT and see only the fourth fan has 4 pins. (dang)
James
This post has been edited 1 times, last edit by "jamesweishaar" (May 8th 2018, 9:07pm)
Similar threads
