• 13.10.2026, 12:16
hossam.sy
Can I use the USB2 Aquacomputer hubby7 splitter to connect multiple Aquacomputer USB devices to Aquaero?
Sunday, January 13th 2019, 6:35pm
Monday, January 14th 2019, 6:30am
No, not really... the only USB connection from/to the aquaero is to the motherboard.
The Hubby7 allows you connect multiple USB items to the hub, which is then connected to a single motherboard USB port.
All the aquacomputer devices will then show up in the aquasuite, where you can control/monitor them.
If you wish to control/monitor aquacomputer devices with the aquaero, you have to use the aquabus connection.
hossam.sy
Monday, January 14th 2019, 11:01pm
So the only benefit of connecting the devices to the Aquaero is using the Aquaero screen to control the parts, otherwise i just can use Aquasuite, correct?
boli
Monday, January 14th 2019, 11:59pm
What devices? The Aquaero is what controls the devices that I know/have * (even when Windows is not running), and Aquasuite is used to configure the Aquaero.
* The devices I know/have are not USB. I think some of them do have control logic of their own (unnecessary when one has an Aquaero). It should say so on their respective product page and/or manual. If true, I guess your assumption is correct (I only have an Aquaero LT without display, no experience there).
This post has been edited 3 times, last edit by "boli" (Jan 15th 2019, 12:01am)
hossam.sy
Tuesday, January 15th 2019, 12:34am
I mean devices like Aqualis XT, D5 Next RGB, Quadro, Poweradjust3,...etc that I have all, so can we connect the Aquabus and USB together in each device or we need to choose one connection per device?
Bartdude
Tuesday, January 15th 2019, 5:59am
you need to connect by usb 1st for the device to be recognised by the pc so having a hubby helps if you have a lot to connect. you can disconnect after and use just aquabus. however I kept my usb connected so future updates are easy to do so in answer to your question yes you can have either or have both :) I have Aquaero 6 xt, 1x hubby7, 1 x poweradjust 3, an mps 400 and 4x splitty 9, 1 of which is setup as aquabus hub. the Aquaero, hubby7, mps400 and the poweradjust are all connected by both usb and aquabus.
This post has been edited 1 times, last edit by "Bartdude" (Jan 15th 2019, 6:05am)
hossam.sy
Tuesday, January 15th 2019, 11:02pm
Danke :thumbup:
